69 f100 team build
Re: 69 f100 team build
Good.work..keep.at it u 2!
-d
-d
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
2014 audi tt Quatro s
Braaaaap!
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
- wndsofchng06
Front suspension is coming together...
- wndsofchng06
Pull the rear diff apart today to fix a leaky pinion seal. Replaced all the seals, including the pinion seal. Checked all the bearings and races for wear. All looked good, Just gotta get some new rear spring bushings to hang the rear axle.
- wndsofchng06
ordered the wrong rear spring bushings.... ugh. Got the rear all re-assembled and the springs mounted (loosely). Took the spring packs apart, de-rusted, primed and painted each leaf, re-assembled minus the bottom leaf....
- wndsofchng06
Found used rotors for now, gotta get the paint off.....
Now I gotta fix this upper coil retainer....You do not have the required permissions to view the files attached to this post.
- wndsofchng06
Pulled from my scrap pile.
Forming the piece....You do not have the required permissions to view the files attached to this post.
- wndsofchng06
Drilled out, welded two nuts on, and you can barely see the NOS from the home made.... ha ha ha ha
- hfdco4
Great progress looks great.
Paul
FE390PC
1970 F250 4x4
2016 F150 4x4 2.7 ECO
Gone 1988, 1989 & 1991 Broncs
FE390PC
1970 F250 4x4
- Ranchero50
Ditto. Don't worry about the painted rotor, it'll sort itself out the first time you hit the brakes.
- wndsofchng06
True on the painted rotor. Any tips for reattaching the yolk and setting the load on the pinion???
- wndsofchng06
Rear bushings are in!!!
- wndsofchng06
shocks came in yellow, had to paint red to fit the theme
Front suspension is all together
- wndsofchng06
holes drilled in frame and sway bar installed
Trans cleaned, primed, and painted.
- hfdco4
Wow lots of progress.
Paul
FE390PC
1970 F250 4x4
FE390PC
1970 F250 4x4
- wndsofchng06
hfdco4 wrote:Wow lots of progress.
Thanks. Can't wait to get the cab back on!
