1970 F250 4X4 Rebuild / Updating
- Manny
Looks good does that graphite paint want to just rub off??? hows durability??
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
- hfdco4
Not sure how the durability is going to be. I have banged them around some putting them on and the paint is still there.
Got some work done the last few days. Both shock mounts and motor mounts, removed cleaned frame and painted. Cleaned mounts and painted, re-installed and looks good.
Paul
FE390PC
1970 F250 4x4
2016 F150 4x4 2.7 ECO
Gone 1988, 1989 & 1991 Broncs
FE390PC
1970 F250 4x4
- hfdco4
Haven't done anything on the frame this week. With the holiday won't get anything done this weekend either.
Paul
FE390PC
1970 F250 4x4
FE390PC
1970 F250 4x4
- Manny
How these projects go have been working on the bronco just hope this weekend the high boy finally gets inside!hfdco4 wrote:Haven't done anything on the frame this week. With the holiday won't get anything done this weekend either.
- hfdco4
Got some things done finally. Cut the drivers side cab mount off and found it was in worse shape so glad its off.
Paul
FE390PC
1970 F250 4x4
FE390PC
1970 F250 4x4
- hfdco4
No progress this past weekend, too dang hot for this fat guy to play! Hope to get back at it tomorrow.
Paul
FE390PC
1970 F250 4x4
FE390PC
1970 F250 4x4
- hfdco4
Still no progress but I think I will get the other cab mount done on the frame. Then start getting the leaf spring bushings out of the frame.
Paul
FE390PC
1970 F250 4x4
FE390PC
1970 F250 4x4
- Manny
Know the pain. Haven't had a chance to touch mine neither. Been meaning to get my thread going. Hope you get some free time here soon.hfdco4 wrote:Still no progress but I think I will get the other cab mount done on the frame. Then start getting the leaf spring bushings out of the frame.
Keep up the good work! I like how your leaving nothing untouched!
Kyle
Kyle
- hfdco4
Drilled out the spring bushings and got the second cab frame mount installed.
Paul
FE390PC
1970 F250 4x4
FE390PC
1970 F250 4x4
- Manny
That's cool need to remember that for the highboy on getting the bushings out.
- hfdco4
The spring bushing i did by using a drill and drill bit to drill out the rubber part. It was horrible, broke several drill bits in the process. This way was much faster and no broken tools. http://fordification.com/forum/posting. ... ilies&f=22#
Now here is what I got done today. Not much but still needs to get done. Cleaned and got the first coat of paint on the cross member so I can hang the front springs.
Paul
FE390PC
1970 F250 4x4
FE390PC
1970 F250 4x4
- Manny
Looking good what springs you running?
- hfdco4
I am running the original 40 year old reconditioned springs. They are complete with pitting and no broken leaves. I dis-assembled them, cleaned and painted them with EZ Slide graphite paint. They came out pretty good. I will post some pics tonight.
Paul
FE390PC
1970 F250 4x4
FE390PC
1970 F250 4x4
- hfdco4
Here is a picture of the front springs as they sit today.
These are the original springs with a 2" add-a-leaf installed about 17 years ago.
Paul
FE390PC
1970 F250 4x4
FE390PC
1970 F250 4x4
