67' longbed build
1guydude
Re: 67' longbed build
Post by 1guydude »
Before the rebuild
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
2014 audi tt Quatro s
Braaaaap!
1guydude
Post by 1guydude »
Tear down
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1guydude
Post by 1guydude »
I love new truck parts! Lol. Got my brake pedal pad in yesterday and was easy enough to install before the carb break down. Today this master cylinder came. Gotta bench bleed it and slap that in. Also im gonna wrap my headers and starter in some heat protection material.
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
Manny
Post by Manny »
Got a question there you said the rotor turned and popped up off the distributor shaft?? Have seen this before when the shaft wear. May be time for a dizzy?? Just curious if that timing issue is causing your starting issue. :?
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
67mann
Post by 67mann »
:hmm: rebuilding carburetors is usually something that requires a nice clean area or am I missing something :? Just would hate to see ya go through all that work and find a pine needle where it ain't suppose to be :thup:
1guydude
Post by 1guydude »
Idk it could be vaccum leak. Starter. Timing. Air fuel mixture.
Yes a clean area helps. Lol. I ran out of time yesterday. I dipped the parts. Some for an hr or so and some for 30min. Scrub with a metal brush. Put em back in. Rinsed in a 5gal bucket with water. Parts are Layed out on a cleaner rubbermaid lid.
Im in the process of picking up my garage and driveway. Make a mess. Clean it up so i can make another.
The rebuild kit didnt come with a choke pull off diaghram which sucked cuz mine looked was damaged and had tears and rips and holes in it.
When i do finally assemble the carb...itll b in a cleaner manner or area ya...im just de greasing and soaking all the lil parts.
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1guydude
Post by 1guydude »
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1guydude
Post by 1guydude »
Well. Rebuilt the carb. Couldnt get the choke figured out. Its broken anyway. The black.cover with the coil.
Dosent matter. I took it to work and the guy said it was a pile. Im open to suggestions for a new one thxs.
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1guydude
Post by 1guydude »
Tore.into the top end to find nice and dirty stuff.
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
DuckRyder
Post by DuckRyder »
1guydude wrote:Well. Rebuilt the carb. Couldnt get the choke figured out. Its broken anyway. The black.cover with the coil.
D
https://www.holley.com/products/fuel_sy ... ts/0-80500
OR
https://www.holley.com/products/fuel_sy ... ts/0-80670
and
http://www.edelbrock.com/automotive/mc/ ... r-bb.shtml
XABN82
Post by XABN82 »
I love a Holley with a manual choke. Think I have a 560 on my 302 with manual choke. I never touch the choke, fires up on the first turn of the key
1guydude
Post by 1guydude »
I think theres light at the end of this tunnel.
My main problem and core to my problems has been the broken header bolts. We took the heads off and you can see thr headers are off. I can take the heads in and get em cleaned, bolts taken out, and new valve spring seals?! I think it was... ?
Anyways. Ill need all new gaskets. Prob a new manifold and carb. And starter.
Till than. Clean and tidy up. Finish till i buy parts.
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
Lone Ranger
Post by Lone Ranger »
Hopefully when you get her all back together it runs great. Keep up the good work!
Those are some purdy carbs but they are not cheap. Maybe one day I'll get one too.
Kyle
Manny
Post by Manny »
Looks good. You made the right choice pulling the heads off. bores and all look pretty good there. Keep her covered up and keep the trash outta it. How does your camshaft look?
1guydude
Post by 1guydude »
Idk we didnt look at that. Thats in the motor or on the distributor?! Idk a lot a out motors. I have an idea but really dont knoe much.
Pulled the headers today and starter. I wanna swap out my brake master cylinder and fix my coupler up a bit if i can.
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
