1968 F100 2wd style side short bed.
- sargentrs
Re: 1968 F100 2wd style side short bed.
Congrats on getting some quality bump time in. Be sure and post a vid of her running with those 40's on her.
- pincheweddo
- Craigerf100
Would they be in Fort Worth Texas, say in your driveway by chance? Lol
1968 F-100 Short Bed
1967 Fairlane 500 Convertable
1967 Fairlane GT/A 289ci SOLD
My Build:
My Build:
- Craigerf100
Bump time? Lol no sarge my will out of town. So no bump time. That's for when she gets backsargentrs wrote:Congrats on getting some quality bump time in. Be sure and post a vid of her running with those 40's on her.
HA! Sorry corny joke
I will. Can't wait to here her scream... my truck not my wife.
My Build:
My Build:
- sargentrs
I'm sooo confuuuusssseeed!
- pincheweddo
This just sounds all kinds of wrong. "Bump time" "Vid of her running" "Here her scream"Craigerf100 wrote:Bump time? Lol no sarge my will out of town. So no bump time. That's for when she gets backsargentrs wrote:Congrats on getting some quality bump time in. Be sure and post a vid of her running with those 40's on her.![]()
- pincheweddo
Naw. I would never insinuate that procurement from my driveway would be in my best interest, only the buyers.Craigerf100 wrote:Would they be in Fort Worth Texas, say in your driveway by chance? Lol
Although it just so happens that I am about to get rid of things I don't need such as a 1969 step side. It's got a nice grill.
- Craigerf100
Tell me more about this 67 aluminum grille you mentioned
My Build:
My Build:
- Craigerf100
Lol sorry sarge I was just being inappropriate. Sorry everyone bad jokesargentrs wrote:I'm sooo confuuuusssseeed!![]()
My Build:
My Build:
- pincheweddo
It was the original that was on my truck before I found the steel one I have now. I am not sure I want to part with that. The '69 grill is in great shape though and could find another home.Craigerf100 wrote:Tell me more about this 67 aluminum grille you mentioned
- Craigerf100
My Build:
My Build:
- Craigerf100
I'm getting a power draw on the driver side front headlight somewhere. And the same side park light is dead.
And my brake lights do not turn on when I hIt the brake peddle.
Aaand the dash lights don't work
Aaaaand the right signal does not work when the lights are on.
Aaaaaaaaand the left rear signal lights up when I put on the right and visa versa.
*sigh*
A few of these came with the truck when I bought it.
I'm guessing bad ground and or a short drawing of something .
Any advice would be awesome
*sigh*
My Build:
My Build:
- pincheweddo
Yuk! I hate those kind of wiring harness issues. This is where a lot of patience is needed to get this fixed.Craigerf100 wrote:I'm getting a power draw on the driver side front headlight somewhere. And the same side park light is dead.
*sigh*
There are 4 harnesses in your truck.
1. Passenger side (plugs into inside)
2. Driver side (plugs into inside)
3. Rear (plugs into driver side)
4. Inside (under dash)
What I would do first is start by checking the entire harness from the cab to the lights on both the passenger and driver side. They are exposed to the elements plus the heat of the engine and will be in worse shape than what is in the cab. After that I would turn toward the harness to the rear to of the truck that plugs into the driver side harness under the hood. Of course your problem could be in the cab (which would be the last harness to pursue) but most the time it will be under the hood.
I would start with driver side cause it is the easiest and you will get a feel for it before the passenger side which has all kinds of stuff going on. Unplug the harness just inside the cab where it passes through the fire wall and carefully pull out the the cab seal grommet. Get the whole thing out by disconnecting the accessories along the way to the head lights.
Once you have it all out. Unwrap the harness and inspect it THROUGHLY. Look for cracks in wires, burned insulation, brittle wire, connections that don't look factory. If you strip a wire and it looks like it has corrosion under the insulation, water has gotten into it and you have to trace that wire back a replace the whole wire. Check all end connection where they plug in to something (like a relay or solenoid) because these get worked back and forth which is not good for 45 year old wire. ANY wire that isn't pliable is a future hazard, if it cracks when it bends, replace it.
When you are repairing damage or previous owner stupidity, make sure you use solder.
Now isolating the problem and fixing it may seem like the way to go, but you will find that if you do the above it will save you a lot of work and worry. Just imagine a shorted wire taking off like a burning fire cracker fuse and melting your entire harness and smoking the whole thing (i have seen it). Once you visualize this you will find your patience.
There are some great wiring schematics on this site. Be sure you reference the color code chart cause it will tell you what the wire is for (link below) This was most helpful for me.
http://www.fordification.com/tech/wirin ... -chart.gif
After you do this you will never be scared of a wire again!
The soldering iron below works awesome!
http://www.homedepot.com/p/Weller-40-Wa ... /100391613
- Craigerf100
Wow thanks for all the info pinch
gonna be a big help.
My Build:
My Build:
- pincheweddo
Hope it wasn't too overwelmingCraigerf100 wrote:Wow thanks for all the info pinchgonna be a big help.
