Wilwood260-8556.
The motor has ford hotrod cams, shorty headers and of course the 2.3whipple. Drives better after the tune than it did stock.
67- SWB, CV swap, 2007 3v 4.6/ 5 sp
- Coupe5oh
Re: 67- SWB, CV swap, 2007 3v 4.6/ 5 sp
-1993 Cobra #121, Black/ Grey leather
-1968 Mustang GT Fastback, Gulfstream Aqua
-1967 f100 pile of parts...
Where did you get your driveshaft at? I'm getting close to that point and should probably get it ordered. Do you mind saying how much it was?
Are you not using the starter solenoid on the starter? I seen you have the stock one on the inner fender.
Chris
Chris
-1968 F100 SWB, 4.6 3V, 5R55S auto, Crown Vic front and rear.
-1968 Cougar XR-7, 351C, AOD, Explorer rear. In approx. 6,000 pieces at the moment.
- Coupe5oh
I had a local driveshaft shop make it. I really don't remember what it cost but I think it was in the 300 range.
I'm just using the stock solenoid as a junction. Intended on getting rid of it for something else but it works.
Sweet build!!
Been over it a few times.
Maybe I missed it.....What was the back spacing on your rears? What size rubber on the front?
Did you end up rolling the front fenders?
2013 Ford Explorer Limited
2005 Ford F350 Lariat - crew/short/6.0L
1972 F100 Sport Custom - reg/short 429/C6 crown vic/Explorer rear
1968 Mercury Cyclone GT 390 - in family since new
1954 Chevrolet pickup - 350/T5 mustangII/Explorer rear
Coupe5oh wrote:Mocked up some fleabay headers I bought to try and gain clearance for steering, and pretty things up a bit. They are gonna help quite a bit I think.
Also got the oil pan switched to one from a crown Vic, as the mustang one didn't clear the crossmember. Tried to notch my factory transmission crossmember and make it work, but since the motor sits so much lower I think it's gonna be easier to fab up something. I'll have to do a little scrounging and come up with some steel to make it out of.
Nice build! I'm planning on doing the CV swap also. Just picked up an 07 PI. Question for ya, what vehicle did you order the headers for? CV or 2007 Mustang? I want to get a set myself. Thanks
-Sean
- Craigerf100
im sure I missed it. but I saw you say your lug spacing is still 5on5.5? how did you swap the front to that spacing? thx
1968 F-100 Short Bed
1967 Fairlane 500 Convertable
1967 Fairlane GT/A 289ci SOLD
My Build:
My Build:
Beautiful work. I'm building mine right now.
Just read the whole build thread. Awesome work!
Does it look like you could have went with long tube mustang headers? I did the front clip and drive line in my 69 bump and was wondering if the long tube mustang headers would clear the steering
