I finalized the A/C install last weekend. Prior to that, I had just installed the dash unit, the compressor and the condenser so I could get the front clip on to move forward with firing the motor.
Since the motor has been sorted out and runs fine, I went back to finish the rest of the hardware install so I can schedule an appointment to get the system charged before it gets too hot around here.
Most of it went without issue, but it certainly has an "aftermarket" fit and feel to it. There are several minor annoying things about the kit, but if it works well in the end, I'll get over it. Here are a couple:
![Mad :-x](./images/smilies/icon_mad.gif)
The heater core tubes exit the unit about one inch out of line with the original holes in the firewall. Instead of using fittings or some other method to use the existing holes, the hoses are plumbed through the kick panel, into the wheel well and then into the engine compartment through the fender apron.
![Mad :x](./images/smilies/icon_mad.gif)
The fan switch replacement had to be modified because it interfered with the nut that holds the whole assembly in the dash.
The heater core was shipped with 2 lengths of hose already attached, instead of one long loop. For any situation other than stock, the two hoses provided are not appropriate. Even in a stock scenario, they both barely reach to the engine bay.
The instructions are poorly written.
There are 2 extra leads in the wire harness that do not get used. This is not stated anywhere in the instructions or on the harness because of their generic nature. The "wiring diagram" is childish, at best.
The center vents below the dash have a cover that does not extend to cover the whole face. The grey foam seal that mates to the bottom of the dash is completely exposed and looks kinda Fisher Price. My short term remedy is a piece of black textured duct tape. I may end up fabricating a complete face plate from sheet metal or fiberglass.
The kit uses the factory control unit, but the lower selector labels are completely irrelevant once the kit is installed. AT LEAST SOME LABELS TO STICK ON THERE WOULD HAVE BEEN NICE. I'll probably end up 3D printing a new face-plate.
And my favorite: The instructions tell you when you need to save or discard items. One of the items to discard is the glove box liner. Unfortunately, my garbage was picked up between the time I put it in the garbage and when I realized I didn't want to throw it out. The kit comes with a VERY shallow plastic glove box replacement. This is because the instructions tell you to route the passenger side vent hose up and over the blower unit. Well, there is more than enough room to route that hose in front of the blower unit, behind the lower portion of the dash, like this:
That leaves all of the room above the blower that was originally there. So, I ordered another factory style glove box from Mac's, but it doesn't fit perfect.
![Image](https://cache.nebula.phx3.secureserver.net/obj/MUNCMDlCQTZFQTAxRjkzQzk0Q0U6MzA5MzM3NDcyMzI0YmIyOWViOWZkMmE4ZWQ5MGQzYmE=?uid=502911fb-3729-4352-8801-80937e6dd460)
