1968 F100 2wd style side short bed.
- sargentrs
Re: 1968 F100 2wd style side short bed.
The first 2 links worked, the last one came up blank. How about your master cylinder? Stock? I've got that booster saved. Thanks!
- Craigerf100
Welp if you havnt seen a head gasket fail externally (Out the side) then here you go
Blew right out the side
Another cylinder was about to blow
I'll be Removing the other side soon.
I've got everything In the order of which I pulled them out.
1968 F-100 Short Bed
1967 Fairlane 500 Convertable
1967 Fairlane GT/A 289ci SOLD
My Build:
My Build:
- SATURN5
Been there before.... Tho this was under about 24lbs of boost, also shortened two rods some.....
Bob
68 F100 Flareside, CVIFS, Cobra IRS, DOHC, M122, MS3, T45, 4.10, Cobra brakes
84 Mustang SVO, B234F, HE351, Full Cobra spec suspension and brakes including IRS, T-tops
96 Mark VIII, Complete chassis bracing, 03 Cobra wheels, Maruader converter, built trans.
- Craigerf100
:ee k:
did Your heads and up beIng warped?SATURN5 wrote:Been there before.... Tho this was under about 24lbs of boost, also shortened two rods some.....
[ Image ]
My Build:
My Build:
- SATURN5
Head....
2.3 turbo SVO. No, I checked the deck when I put it on the new shortblock. This time filled with Crower rods and modified Diamond pistons.
Bob
- Craigerf100
You only replaced one head gasket? I've played with idea of boosting my 302 after I get the body and paint done.SATURN5 wrote:Head....2.3 turbo SVO. No, I checked the deck when I put it on the new shortblock. This time filled with Crower rods and modified Diamond pistons.
My Build:
My Build:
- chad67
Craiger,
Did it score the surface of the head or block? It kinda looked like it may have in the pic with the gasket in place on the head. Of course pics can be hard to see online....
1967 F100 SWB
1991 Thunderbird 5.0 with fully ported gt40 heads, cobra intake (also ported) and a trickflow stage 2 cam, manual steering, and custom 3" exhaust
- Craigerf100
I'll look and see. The pic sure looks like it.
My Build:
My Build:
- Ranchero50
Ditto, looks torch cut and it'll do it again if the gasket surfaces are eroded away. Mine used to look like goose eggs when the pushed out the side.
- Craigerf100
Well great thought I might get lucky and just do a gasket job.
My Build:
My Build:
- Craigerf100
Ok so is this video valve adjustment accurate for my stock 302?
Ford Mustang 302 Valve Adjustment in under 8 minu…: http://youtu.be/3xM1v1HZ2Wg
The rockers look a bit different and it's aluminum heads is why I ask.
My Build:
My Build:
- chad67
Better check the block for scoring, too. As far as the rockers, I couldn't tell from the pictures if yours were bolts or studs.
1967 F100 SWB
- Craigerf100
Thanks chad, yeah I plan to resurface/mill the heads.
Been doing some research on a quality brand and type of gasket. I've found good things about felpro's composite head gaskets.
http://pages.ebay.com/motors/link/?nav= ... 90&alt=web
I would like all your :2cents:s
My Build:
My Build:
- chad67
You need to check the block, too. If it torched the head, the block may be bad, too. I know this isn't what you want to hear, but if you put it together with the block bad, it will blow the gasket and torch the head again.
1967 F100 SWB
- Craigerf100
Ok so, took a scraper to the heads and the block. and most of what looked like scoring on the head came off; must of been mainly carbon build up. The blocks 'looks' fine. But time will tell I've only begun cleaning the surfaces. Wish me luck.
My Build:
My Build:
