71 XLT 390
re: 71 XLT 390
The side bolts and extra webbing makes the bottom end hold together with the high stress of a 4.5 to 5.25 inch stroke. So a re-sleeved 360 with that bottom end set correctly to cross bolt mains with 427 sleeves bored at .060 over and 4.5 crank would be 520 cid. A 4.25 stroke would be 491 and a 5 inch stroke makes 578.2 cid. Now with the 427 sleeves at .080 over you get 4.23+.08 for 4.31 / 2 = 2.155 squared * pi for piston area 14.590 sq in * 4.75 stroke * 8 cylinders equals 554.4 cid. Last block on the 427 re-sleeve at .030 would make a 4.26 bore and with the max crank stroke the block could handle of 5.25 you get 598.6 cid.
The reason I say borderline is engines not engineered that large don't last very long in racing. They still break from the crank stressing the block at high RPM and severe piston to side wall flex.
In this pic the red line from blue dot is an example of large stroke say 5.25. It hits the sidewall at a high angle and overloads the sidewalls and the piston skirts fairly easily. The green dot and yellow line is what happens at a 428s stroke a lot less sidewall loading making the engine last longer. I plan on taking my 360 out to 376 by boring it out and destroking it to keep the torque and gaining cid plus a super low friction crank setup because of low sidewall loading.
- XLT
Re: re: 71 XLT 390
DuckRyder, I am unable to get images from . I have even done a search on Google. No images.DuckRyder wrote:About the 5th picture down on this page shows the webbing pretty well.
http://www.428cobrajet.com/id-block.html
XLTrucks from my town
- DuckRyder
Re: re: 71 XLT 390
Try these, they are direct links to the pictures.XLT wrote:DuckRyder, I am unable to get images from . I have even done a search on Google. No images.DuckRyder wrote:About the 5th picture down on this page shows the webbing pretty well.
http://www.428cobrajet.com/images/fe-normal-web.jpg
http://www.428cobrajet.com/images/fe-triple-web.jpg
HTH
- XLT
Re: re: 71 XLT 390
No images... too.DuckRyder wrote:Try these, they are direct links to the pictures.XLT wrote:DuckRyder, I am unable to get images from . I have even done a search on Google. No images.DuckRyder wrote:About the 5th picture down on this page shows the webbing pretty well.
HTH
- DuckRyder
re: 71 XLT 390
I'm about out of ideas for you to see them then, unless I can make them show here:
[edit: nope that didn't work.]
Go to:
Under: Engine Information Resources
Click: Component Identification
Then Click: Block
That should get you to the original page where the images are.
Perhaps they have it set up so that you have to go in the front door.
If that doesn't work
Go to:
Then Click: Block
Re: re: 71 XLT 390
Too many redirects occurred trying to open “http://www.428cobrajet.us/home/n28cob2/ ... .jpgâ€ÂXLT wrote:DuckRyder, I am unable to get images from . I have even done a search on Google. No images.DuckRyder wrote:About the 5th picture down on this page shows the webbing pretty well.
- XLT
re: 71 XLT 390
Is anyone else unable to get images from http://www.428cobrajet.com/id-block.html
- XLT
Re: re: 71 XLT 390
Maybe right click on images, click properties, copy address and paste images here?DuckRyder wrote:I'm about out of ideas for you to see them then, unless I can make them show here:
I went back the Cobra Jet web sight, and VOILA ! The images appeared.
- DuckRyder
Re: re: 71 XLT 390
I already tried that... (where it says "nope that didn't work...") They have them forbidden to remote link...XLT wrote:Maybe right click on images, click properties, copy address and paste images here?DuckRyder wrote:I'm about out of ideas for you to see them then, unless I can make them show here:
What browser are you using?
