Starting Problem
- crash_552
Not necessarily. Yes I do know from personal experience, I had one come loose, it wasn't much but enough to cause a grinding noise like a bad starter.kid wrote:If the ring gear came loose it would make a hell of a racket as it ate everything in the bell housing area.
Good judgment comes from experience... and a lot of that comes from bad judgment
http://www.fordification.com/galleries/ ... ?album=731
- bigman78
re: Starting Problem
Well, depending on when I get paid were going to take it to my uncles and do a bunch of work to the truck. When that happens well drop the tranny and might even rebuild it while its out.
1967 F-250 4X4 Highboy, 429, D60 rear, D44 front, NP435 trans, Dana 24 T-case, PTO winch
http://profile.myspace.com/index.cfm?fu ... =136460833
http://www.fordification.com/galleries/ ... ?cat=10577
I have had it destroy the clutch and bell housing and flywheel. On the street at daily driver speeds.crash_552 wrote:Not necessarily. Yes I do know from personal experience, I had one come loose, it wasn't much but enough to cause a grinding noise like a bad starter.kid wrote:If the ring gear came loose it would make a hell of a racket as it ate everything in the bell housing area.
If you get one, their easy to swap. Gotta pull the flywheel first.
- crash_552
Ouch!!! That sucks.I have had it destroy the clutch and bell housing and flywheel. On the street at daily driver speeds.
- bigman78
Fixed it! turns out all it was was a burned up solenoid. That makes me happy. I still plan on replacing the flywheel though. Thanks for the help.
- bigman78
Well, I finally figured out the real problem after going through 2 new solenoids. Turns out it was the starter and a faulty wire for one of my guages which made that guage always on which in turn drained the battery every night. Anyways, I pulled the starter and the teeth on it were pretty worn so I took it down and got a new one and the truck starts better than it ever has.
