door gaskets
- CH3NO2
Re: door gaskets
When I did mine I just did about 18" at a time,that way I did'nt have all that glue to accidently run into.Also they make that gorilla snot glue in black now .It works real well.
Re: door gaskets
IF you use the gorilla snot and let both sides dry you shouldn't need any tape. You have to be very careful though since once one side touches the other it is glued. Just like using contact cement to glue down new lamented counter tops. Some real nice looking interiors.
clint
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
