fuel tank swap.(pics)
td
Re: fuel tank swap.(pics)
Post by td »
427blackpearl wrote:hey td i found them. looks llike around 110 or so
http://streetridepro.com/advanced_searc ... c_subcat=1
thanks Brad! if i wasn't all ready over budget on this little project i'd buy one of those,but im getting the material to fab one give to me so i cant beat that deal :thup: we're gonna do the notch fri. so i'll take a few pics as we go to post.
427blackpearl
Post by 427blackpearl »
i will do this some time too. do you think is a good deal then?
not mutch on this fab stuff so it being a bolt on thing kinda
td
Post by td »
427blackpearl wrote:i will do this some time too. do you think is a good deal then?
Brad,
yea i'd say thats a good price, if i had that one i'd already be done with this little project. ive been waiting on a freind of mine to help me with the notch on fri. :thup: :thup:
bbfhnj
Post by bbfhnj »
what ohms is the sending unit? i might sell my poly fuel cell and get one of these.
td
Post by td »
bbfhnj wrote:what ohms is the sending unit? i might sell my poly fuel cell and get one of these.
thats one of the coolest things about the swap, since its a ford tank from the same era the ohms are the same as your stock unit. :thup:
bbfhnj
Post by bbfhnj »
gosh i love this site :fr:
BobbyFord
Post by BobbyFord »
There is also a 22 gal version, 1970 Mustang I think. Same outside dimensions, just deeper.
td
Post by td »
BobbyFord wrote:There is also a 22 gal version, 1970 Mustang I think. Same outside dimensions, just deeper.
there's a 20 for 68-69 stangs and your right the 22 is a 70 i have a couple links here on them. only thing is the extra capacity is made in the top half of the tank and you'd have to watch for bed clearance. i think the 20 gal. would work for sure and probably the 22 but clearance would be something to watch for.
the 20 gal.
http://www.mustangsunlimited.com/itemdy ... y=emustang
the 22 gal.
wt4speed#2
Post by wt4speed#2 »
Hey td looking good. Your "c" notch idea with the pipe is whats been rolling around in my little vaccum space of mind for a while. Just wondering how far you went in lowering proccess for the rear?Just the hanger inversion or a combination of things.
Tony B.Image
DFW Area
"Someday...
I hope you to get the chance,
to live like you are dying"
Member#'s 236 & 403
Úlf the Comedy Sidekick
wt's ride
thebucket
td
Post by td »
wt4speed#2 wrote:Hey td looking good. Your "c" notch idea with the pipe is whats been rolling around in my little vaccum space of mind for a while. Just wondering how far you went in lowering proccess for the rear?Just the hanger inversion or a combination of things.
wt4speed,
along with the hanger flip i removed 1 leaf. when i bought the truck it had 4 leafs and the overload now it only has 3 and the overload.
i don't know the thickness of the material that the aftermarket bolt in c-notches are made out of but i was planing on using 3/16th to box in the inside of the frame after i cut the notch and welded in the pipe. as ive studied this closer ive noticed that the upper shock mount really needs to be moved out of the way to be able to box it in as far forward as i need to.
so now i'm wondering if you have to box the frame with the bolt-in notch :? , does anybody know if you have to? :? if not i may just spend the $ and get the bolt-in to keep from having to move my shock location.
anyway its all back together minus the c-notch until i figure the shock problem out. its now running off the new tank and its all working good. here's a before and after so you can see the improvment.
before.
after.
the tank.
wt4speed#2
I went to the link that was posted above for the bolt ins above and clicked on related products for the early models(ie relating to our application)and it has a pdf link that gives brief installation procedures, no mention of boxing the frame there. You might check it out and read it your self in case i might have missed something. Tried to get it to post in this thread no dice.
Tony B.Image
DFW Area
"Someday...
Member#'s 236 & 403
wt's ride
thebucket
427blackpearl
looks good td, looks real good :thup: 8)
td
Post by td »
427blackpearl wrote:looks good td, looks real good :thup: 8)
Thanks Brad, ive busted my hump on this thing to the point were im ready to take a break from wrenching for a little while. :thup:
ford4x4fun
Post by ford4x4fun »
Your not alloud to get tired of wrenching I figured once you where done with yours you could just cruise up to Clarksville and start on mine :lol: Your project does make me want to get back home and get to mine :thup: I am buying one of those gas tanks for myself for Christmas!
CNR Radio Instructor
US ARMY Retired
1971 Ford F100 4x4 (390)
2015 Ford F250 Crew Cab 6.7l
td
Post by td »
ford4x4fun wrote:Your not alloud to get tired of wrenching I figured once you where done with yours you could just cruise up to Clarksville and start on mine :lol: Your project does make me want to get back home and get to mine :thup: I am buying one of those gas tanks for myself for Christmas!
fors4x4fun,
there's nothing wrong with a little gift to yourself from yourself ! :lol:
