F-600 cluster
Bobaloo2
Re: F-600 cluster
Post by Bobaloo2 »
Thats it, I got it at Advance I think, it's about 6" wide, you peel off the back and stick it on, the secret is, be sure to peel the clear covering on the front, (it's a bugger to get started)then it pops like chrome. The tape is fairly thick, so maybe it will hold up being at the top of the dash, where it really doesnt get handled.
Bob
Bobaloo2
Bob Mayben
1967 F 100 SWB
1963 Bel Air 409
Re: F-600 cluster
that is an excellent idea. cananyone say plastic bezel recovering material?
kaptnkaos
Re: F-600 cluster
Post by kaptnkaos »
Wow, I had no idea... never even seen the stuff B-4
Looks good... hope it works well, so we can see how it goes...
KaptnKA 8) S
Bobaloo2
Re: F-600 cluster
Post by Bobaloo2 »
I have complete pictures coming of how I did my dash.
Bobaloo2
Bob Mayben
1967 F 100 SWB
1963 Bel Air 409
Bobaloo2
Re: F-600 cluster
Post by Bobaloo2 »
Whatdayau'll think? The clock is a $2.00 item from a discount store, I made the new face with the Ford emblem.
The hard part is cutting away the back of the original cluster housing, to clear the after market gauges, and leave space for the turn signals and speedo.
Bobaloo2
Bob Mayben
1967 F 100 SWB
1963 Bel Air 409
SteveK
Re: F-600 cluster
Post by SteveK »
Really like to see that panel when it's all done.
1998 Ford Ranger ( the wife commandered from me)
1997 F 150 4X4 SB ( for sale)
1978 F 100 LB 4X2 ( for sale)
1968 F 100 LB 4x2 ( My baby)
1968 F 100 LB 4x2 (just purchased for parts)
1977 Harley FLH Full dresser (my other baby)
1930 Ford Fordor Town sedan ( restored )
la1031
Re: F-600 cluster
Post by la1031 »
bobaloo,
Did ya see what i meant by how much time I had in that thing?
Grinding those holes out and clearancing the backing plate was very difficult. It looks like you are using a stock gauge, looks great. I am also putting a clock in the hole to the right, but mine matches the SW stage 3 gauge set that I have. That darn clock was the most expensive gauge in the set BTW, they say its the same one used on Shelby mustangs from the 60's. I need to post assembled pics but my cluster is on hold to be painted along with the truck.
http://s446.beta.photobucket.com/user/1968F100/library/
1968 F100 Shortbed
302/306 roller, C6 w/shift kit
3.70POSI w/trackbars
Hydro-Boost
Hoping for 13's and looking good doing it !!
Makita Industrial Power Tools
Tools for the long run.
Bobaloo2
Re: F-600 cluster
Post by Bobaloo2 »
I do. It took waaayy more time than I thought. If I had a drill press that would have been nice.
The tach is a Sunpro, the oil,water and volts are Auto Gage, the fuel level is an Equus. It doesnt match perfectly, but I am going to try to work on that. The Equus is supposed to be a plug and play for the stock Ford sender. I hope so. I may re do the clock face with smaller numbers, I would like it to match the tach a little closer.
Cant wait to see yours finished.
BM
Bobaloo2
Bob Mayben
1967 F 100 SWB
1963 Bel Air 409
wickedinhere
Re: F-600 cluster
Post by wickedinhere »
HEy what did you do about the glass covering the original gauges?
You can pay more but you cant buy better.
Bobaloo2
Re: F-600 cluster
Post by Bobaloo2 »
I cut a piece of Plexiglas I got from Lowe's,pretty thin, I think it was like $5.00 or so.
I am going to try to get it in this week.
Bob
Bobaloo2
Bob Mayben
1967 F 100 SWB
1963 Bel Air 409
wickedinhere
Re: F-600 cluster
Yeah thats what i was thinking of doing. I tried cutting my holes with the holesaw i bought on my drill press but the holesaw would bite to hard on the cluster.
I ended up cutting the holes with my plasma cutter and then grinding the rest of the way so the gauge would fit.
cmoore
Re: F-600 cluster
Post by cmoore »
Bobaloo2....nice job man. That cleaned up really nice and has that vintage look to it too. I almost bought a '64 F600 with a dump bed on it, went with a '70 CS instead but I do want want one of those clusters. Much easier to read, ergonomically better overall....
Regards...
cmoore...
out...
1970 F250 SC, 360ci, C6, rattle-can black, 17" MB chrome wheels
hotrod ford
Re: F-600 cluster
Post by hotrod ford »
bobaloo2, looking good. it is making me miss the one that i had in my 68 f250.
la1031
Re: F-600 cluster
Post by la1031 »
Okay Update on mine....
Some parts got painted, and here is the cluster with gauges mounted loosely
1968 F100 Shortbed
Hydro-Boost
