Sent you a PM59yblockf100 wrote:i have a few 67-72 f100s and older trucks i am parting out,i have alot of parts,if you need something let me no,i will be adding parts as i get them off,thanks
1967-72 f100 parting out
Re: 1967-72 f100 parting out
1969 F100, 390, 3 Speed, 2WD
no brake booster,or power steering,thanks
Ok thanks59yblockf100 wrote:no brake booster,or power steering,thanks
- mouse
do you happen to have a z bar/equalizer frame side bracket
1971 F100 sport special 390 fe
1993 F250 4X4 ext-cab 6.9 idi
off a 360 v8 i do,
I'm looking for the brake /tail/marker light wire harness that goes in the bed. From 70-72 I believe. Needs to have plugs for the red marker light at the end of the bump. Thanks.
1967 f100 4x4
1970 f250 4x4
1970 f250 4x4
will check on the wiring,
Steering column for 3-speed on-the-tree with power steering....my understanding is this column is slightly different than 3-speed w/o power steering. Truck is 1966 Ford F-100 352 v8. Could also use p/s pump, crankshaft pulley, and Bendix steering box if you have them. Thanks.
Would you happen to have a long wheel base truck bed for a F -100? 72 Styleside thanks
Any dash pads???
Also bench seats.. I'm restoring a 68' F100 it was my fathers
- Abrams
Heya, any chance you have the non ez-ride F250 leaf springs and cab to rear tail light harness available?
A
A
- Keoneeli1
Hey there,
I am looking for something to install my 5.0 302 engine into my '66 F100, which has a straight 6, but I am looking for something to install my 5.0 302 V8,
Do you have anything to put the 5.0 302 engine in my '66 F100?
Please let me know what you may have!
Thanks for your time!
David Cawdrey
David Cawdrey
