my dad and I got lots of work done on it
when we went out there, we had no clue where to start! then we decided to first replace the broken T's. once that was done, we re-glued joints that arnt suppose to move with better glue. then we ran two cables from the sides of the structure. Then, I got on my truck cab and camper (scary!, i was really carefull on where i stepped), and I pushed the roofing stuff up so it all had a angle again. then my dad ran around and pushed all the connectors and stuff together while I had the stuff straight and lifted. then he ran more cables to keep the roof arch, and glued stuff. Then we ran more cables
and then we were done
BEFORE! (after we took off the tarp)
the cement bags we used to weight down the tarp are now everywhere
AFTER
if you look really hard in these pictures you can see the white cables.
try to find all 6 cables
my dad has a few ideas to help support the roof and prevent sagging. one is we can arch flexible wood (stuff used as little garded walls) over the top so the water would flow frealy off, OR we could just run some more pvc pipe.
PLUS the tarp will be much tighter this time, and will be trimmed to fit the structure, unlike before when we had 15 ft of extra tarp in each corner.
the tarp and roof supports (whatever that may be) will go one in two weeks because i have to study for finals in school. BOring!
OH, and i got some work time on the truck
see my 69 project thread for what i did. nothing major.
