my green 68
Show us your rides or projects!
tybob81
Re: my green 68
Post by tybob81 »
newly covered 95 f150 seat.
tybob81
Re: my green 68
Post by tybob81 »
Dusty engine compartment. Doing some rerouting of the painless harness.
Zorm
Re: my green 68
Post by Zorm »
how did you do the wood in the bed?
tybob81
Re: my green 68
Post by tybob81 »
I built new rear and center crossmembers and modified the front crossmember. Made a track on the sides for the wood to slide into also.
BiggDogg
Re: my green 68
Post by BiggDogg »
Wow, that has got to be one of my top 10 favorite bumps. Very, very nice. :thup:
1970 F250 Camper Special
72biggreen
Re: my green 68
Post by 72biggreen »
BiggDogg wrote:Wow, that has got to be one of my top 10 favorite bumps. Very, very nice. :thup:
:yt:
undertakerman
Re: my green 68
Post by undertakerman »
I like your color. Green is one of my Favorites. I'm restoring a 68 Flareside 8' bed and I'm painting it Sassy Grass Green which is a 69-70 Mopar color. I use to have a 69 Roadrunner that was Sassy Grass Green with Black interior. This interior will be Black on Green. Good looking truck. You did a great job.
You know man can live alone, but he cannot live without Peanut Butter and Grape Jelly.
72shortbed
Re: my green 68
Post by 72shortbed »
Great looking color. And awesome work on your truck. I only hope I can do that well on mine.
wwjd63
Re: my green 68
Post by wwjd63 »
tybob81 wrote:[ Image ]
:eek: that is the coolest green i have ever seen. :clap:
jreyes
Re: my green 68
Post by jreyes »
nice color and it looks that u have done a great bodiy work also!!!
tybob81
Re: my green 68
Post by tybob81 »
Thank you.....I have a ton of hours blocking this truck till it was straight as an arrow.
Calvin Gunter
Re: my green 68
Post by Calvin Gunter »
Hey tybob81,
I see you have a tilt column in your beautiful truck, what brand and part number did you use?
Any problems with the install ?
TIA,Calvin
tybob81
Re: my green 68
Post by tybob81 »
It is an early IDIDIT column for a 67-72 truck. It is the metal housing one. I think they have a ford plug now, nut this one had a gm plug and o made an adapter plug from an old column to plug a gm into a ford painless harness.
Calvin Gunter
Re: my green 68
Thanks tybob81,
Do you remember the part number you used?
I see they have a retro fit for our trucks.
Was yours a direct bolt up or did you have to modify anything other than the wiring.
TIA,Calvin
tybob81
Re: my green 68
Post by tybob81 »
Bolted right up an as far a a part number I can look....been over 5the years since I bought it.
