The notches do look like good quality and your welds are very nice as well. Did you think about additional support (boxing) on the inside? Structural analysis I've seen makes me nervous about this type of notch without an inner vertical member. Perhaps I'm sensitive because I intend to tow with my truck.rms wrote:Thx! The c-notches are from eBay, seller dchopshop.Lowell wrote:Enjoy watching and reading your build, very nice work. If I may ask, where did you source the c notches from? They are as nice as I have seen on several different project forums.
'69 overhaul- CV, 8.8, and more.
Re: '69 overhaul- CV, 8.8, and more.
1970 F100 Ranger 2WD
project link: http://www.fordification.com/forum/view ... 22&t=83642
Thank you. It’s hard to see when painted, but I did add a 1/4” plate “mini-box” to add some rigidity.
-Ryan
1969 F100
1969 F100
I finally got the engine mostly buttoned up, mated the transmission, and put them in the truck. The engine is a LQ9 6.0 from a 2003 Cadillac Escalade. I went through it replacing the cam, lifters, valve springs, oil pump, and obviously gaskets. The cam is a 224/230@.050 and .550". I've dumped the factory EFI in favor of a carb. It should be pretty stout. The transmission is a BOP TH400 with a manual valve body and 3000 stall. I had this trans from a previous project, so for now it's getting used, although I see OD before too long.
This is just mocked up, but I'll probably go with it.
They don't make a LS to BOP TH400 adapter plate so I had to modify a SBC to BOP TH400 adapter plate. It required welding on 3 studs and offering clearance for the LS rear cover bolts.
Lastly, I decided to replace the wiring harness. That should be fun.
-Ryan
1969 F100
1969 F100
- Manny
Looking good. Ron Francis wiring has a pretty good reputation. Curious to see what you think of it during your install.
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
Thx! Electrical isn’t really my thing, so I’ll be glad when it’s done.Manny wrote:Looking good. Ron Francis wiring has a pretty good reputation. Curious to see what you think of it during your install.
-Ryan
1969 F100
1969 F100
- Manny
You'll be fine ain't nothing to it!rms wrote:Thx! Electrical isn’t really my thing, so I’ll be glad when it’s done.Manny wrote:Looking good. Ron Francis wiring has a pretty good reputation. Curious to see what you think of it during your install.
Got a bit more of the engine assembled, mounted the MSD box, and installed the universal transmission crossmember. I couldn’t use the factory crossmember as the exhaust would hit it.
-Ryan
1969 F100
1969 F100
Mr RMS, It is looking good.
Thank you for posting all the photos and information, I have enjoyed it.
Making some progress on the truck. I’ve now have it wired enough to start it. Think I’ll fool anyone with the 289 air cleaner?
I have one side of the exhaust done.
Starting customizing my Holley digital dash.
-Ryan
1969 F100
1969 F100
- DuckRyder
Well, that seems to be coming right along...
I do agree it was pretty cool before... Considering that exact wheel/tire set up for mine, wish I had known they were for sale...
Anyway, keep up the good work!
Thank you, and I have trouble leaving anything alone!DuckRyder wrote:Well, that seems to be coming right along...
I could fiddle with the customization of this Holley dash for days. I started with a blank screen and ended up with this, which I like better than the preloaded option above. Pictures don’t really do the display justice.
-Ryan
1969 F100
1969 F100
I have the fuel system pretty much completed. I’m pretty close to firing her up, hopefully not too much longer.
Started plumbing brake lines.
And of course made a new dash display.
-Ryan
1969 F100
1969 F100
Do you remember the shock mounts being hard to keep centered on the leaf? I put mine on a little while ago. Just temporarily and it seemed like they'd move around easily. Plus, the shock didn't align great. Did you change the mount angle to make it work?
I had to get rid of the Explorer shock plates when I bolted on the Cal-tracs. I do remember the angle just being slightly off, making it somewhat difficult to push the shock onto the frame mount stud.Do you remember the shock mounts being hard to keep centered on the leaf? I put mine on a little while ago. Just temporarily and it seemed like they'd move around easily. Plus, the shock didn't align great. Did you change the mount angle to make it work?
-Ryan
1969 F100
1969 F100
-Ryan
1969 F100
1969 F100
