'70 Sport Custom Rebuild- She's been adopted!
- sargentrs
Re: '70 Sport Custom Rebuild- F600 Gauge Panel Mockup.
Thunderstorms here today so crawled down into the man cave for a little quality time with truck parts.
- sargentrs
Since the rattle can chrome didn't look very good, I decided to go with glossy black on the gauge panel. Before the final coating I figured I better mock up the switches, lights and gauges to make sure everything fits. Of course, to make sure this stuff fits, I actually had to buy some Went ahead and bought the tach, fuel pressure gauge, LED billet button switch (for fog lights and whatever), indicator light switch (for brake warning light) and mini LED's for turn signal indicators.
- sargentrs
Re: '70 Sport Custom Rebuild- F600 Gauge Panel Mod
Indicator light and LED turn signal lights...
- sargentrs
As I test fitted the tach, I realized I'd need back up rings like I needed the spacer rings on the front. I whipped some out of some thin sheet metal with my aviation snips. Since they're on the back side, appearance was not much of a concern. Had to ream out the holes for the lights and switch with my dremel and a grinding stone. Then I installed the other components. Everything fit pretty good.
- sargentrs
More pics
- sargentrs
After scratching my head awhile about how to mount the turn signal indicators, I scrounged up some scrap aluminum and fabbed up a bracket I think will work.
- sargentrs
Now I can finish painting the bezel, rings and brackets and the gauge panel will be ready for the rest of the gauges and switches...when I can afford 'em!
- sargentrs
Progress is progress.....
- SeapineF37
oh man panel is looking rad! dig the black and that custom braket for the led lights turned out great.
gauges are expensive for sure. few at a time though... and be there before long. loving this thread!
thanks for the inspiration. cheers!
1972 F350 seapine green cab/chassis drw
only one who has learned much can fully appreciate his own ignorance. louis l'amour
- sargentrs
Thanks Seapine!
- sargentrs
Thanks EDVSU!
- 48prerunner
Looks nice I still have a painted version sitting around. The turn signals windows the arrows originally have a geen tranlucent plastic( probably could use those binder tabs) that looks like it was scotched tape to the panel. Then there are these cardboard tubes to direct the light to them. The tubes in a stock panel work with a little mod. I misplaced my f600 tubes at time of assembly and used ones out of a f100 panel of course once in the truck they were found.
http://www.staples.com/Avery-WorkSaver- ... t_SS992814
- sargentrs
Thanks for the lens idea, 48prerunner! I was just thinking about what I was going to use yesterday. That'll be quick and easy. And I didn't even remember about the tubes, it's been so long since I took it apart. Guess I'm not quite finished with it yet!
Mr Sargentrs, thank you for all the good information & pictures.
Things are looking good.
