1970 F250 4X4 Rebuild / Updating
- hfdco4
Had to do yard work this weekend. Since I had the power washer out I cleaned up the Blazer Skip Plate. Surprisingly enough it still has some original paint on it. I do have some grinding to do and get a coat of rust inhibiting primer on it.
Paul
FE390PC
1970 F250 4x4
2016 F150 4x4 2.7 ECO
Gone 1988, 1989 & 1991 Broncs
1970 F250 4x4
- hfdco4
Have been working slowly as its hot here and I am fat and old. Just the facts of life. I got the extra holes in the drivers side of the frame welded up. I hope to take a few days off this week and get the passenger side done and get the tank set in place.
Paul
FE390PC
1970 F250 4x4
1970 F250 4x4
- hfdco4
Got some more done this weekend, I will post some pictures tomorrow. Set the new tank in the frame rails and got the skid plate cleaned and painted.
Paul
FE390PC
1970 F250 4x4
1970 F250 4x4
- hfdco4
Have some updated pictures;
Here is the frame with the extra holes welded closed at the rear axle spring perches.
Paul
FE390PC
1970 F250 4x4
1970 F250 4x4
- hfdco4
Passenger side;
Paul
FE390PC
1970 F250 4x4
1970 F250 4x4
- hfdco4
Started the gas tank work now too;
Paul
FE390PC
1970 F250 4x4
1970 F250 4x4
- hfdco4
Frame mods and tank height.
Paul
FE390PC
1970 F250 4x4
1970 F250 4x4
- hfdco4
Tank height from the side.
Paul
FE390PC
1970 F250 4x4
1970 F250 4x4
- hfdco4
Got some work done refurbing the rear springs.
Now I have to finish the other spring. It took longer to dis-assemble clean and paint than I thought it would. The results are worth it though.
Paul
FE390PC
1970 F250 4x4
1970 F250 4x4
- hfdco4
Got some work done on the Gas Tank mounts.
Paul
FE390PC
1970 F250 4x4
1970 F250 4x4
- hfdco4
I need to sandblast now then add some gussets at the rear spring mounts. Then make the mounting pad for the 78/79 style power steering box.
Paul
FE390PC
1970 F250 4x4
1970 F250 4x4
- SeapineF37
progress is looking good
1972 F350 seapine green cab/chassis drw
only one who has learned much can fully appreciate his own ignorance. louis l'amour
- hfdco4
Still working on the frame. I am going to add some bracing around the the rear spring mount area that had the cross member removed from. I did get a new tool box this weekend so now I can organize things better and be able to find what I need (as long as I put it back).
On Sunday I took my wife to the NASCAR Race at Dover and watched our boy Chase Elliott finish third and make the cut to the next round.
So all in all a great weekend.
More pics to come on the frame strengthening.
Paul
FE390PC
1970 F250 4x4
1970 F250 4x4
- hfdco4
I have been lax on my posts so time to catch up.
I have been reinforcing the rear frame area at the spring perches. I am using parts of the 2 wheel drive frame as material.
Paul
FE390PC
1970 F250 4x4
1970 F250 4x4
- hfdco4
Here is what it looks like now.
I added flat bars and a plate to allow for access to the spring perch bolts.
Paul
FE390PC
1970 F250 4x4
1970 F250 4x4
