What did you do to YOUR bump today?
No tech discussion, please
67F110
Re: What did you do to YOUR bump today?
Post by 67F110 »
Got the bed set on. Got the title from the previous owner. I guess it's official!
BEHOLD.... Captain America!
cdeal28078
Post by cdeal28078 »
Too it or with it? lol I was helping my sister's son in law cut some fire wood. It was dumped off with a tiltbed. It was a mess and I got tired of climbing around in it with a chainsaw trying to cut it so he could split it. He has never run a saw or splitter so he was running the least dangerous. I finally got my straps out and told him how to go about tying the strap around a log so I could pull them out to get too them. I didn't realize he was tying up to 3 of them things at one time.
He said go ahead and I put a little pressure to the gas. I felt one tire slip a bit and then lock up. Right side was on the dirt but the left was on asphalt. I also have a Lock-Rite in the rear end. Once it locked up I gave her some more gas and with little trouble pulled 3 Ash logs about 18" diameter and abut 15' long out from under a pretty good pile of logs.
Not much trouble for a F250 or 4 wheel drive I know but I was right proud of my little F100. lol Sure was fun and beat climbing around in there.
Clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
67F110
Post by 67F110 »
Installed headlight switch (thanks Fordman's ebay auction!), removed rusty, thrashed painted mirrors. Attempted to install a new negative battery cable, only to find that 32" is not long enough. Removed the sill plates and took a peek under the floor mat to check the condition of the pans. Lots of dirt, some rust, but no holes!! woohoo!! Thought about filling the trans, but I had my good clean In-N-Out t-shirt on. No way I was going to crawl under and thrash it. I'll wait until I can move under cover. Next up... battery to go with the cable and a muffler.
Off The Jeep End
Post by Off The Jeep End »
Saturday I installed a new fuel pump and drove it around for the first time in a month
hotrod ford
Post by hotrod ford »
removed the grille, radiator support and disconnected all hoses and wires from the eng. should pull it and the tranny tomorrow to get ready to refresh the engine.
wildcard
Post by wildcard »
Had a new tire put on front after a blowout. First time I have ever actually had a tire shop torque the lug nuts. And it was a young man working after school. He was admiring my truck and telling me about a 65 he's trying to restore. Also had a guard at the main gate of the Army Depot stop me to ask about it. Thought at first I was in trouble but he just wanted to talk about Ford trucks. Not a bad day except for the price of tires. And they seemed reasonalbe enough.
sport71
What I did today
Post by sport71 »
I put the fuel line that splits in two to the holley carb, because the one it had, had a very small hole in it. Put on the throttle linkag, and the passing gear rod. Also put the gear shifter linkage. Then bleed all 4 disk brakes. Started the truck and lit up the tires like nobodies business. It's a scarry monster beleave you me, I couldn't beleave how powerful the motor came out...
Those who do not learn the lessons of history, are doomed to repeat it.
bluef250
Post by bluef250 »
Put second coat of touch up paint on tool box.
austin
Post by austin »
i started sanding some of the rust off today to prepare it for some rustolem but it got way to cold so i gave up
68CamperSpecial
Post by 68CamperSpecial »
Wet sanded the whole truck getting it ready to paint on Friday. And, tried to track down those little rubber pieces for the hood side name plates but no luck :?
Learning something new about these trucks every time I log-in
flyboy2610
Post by flyboy2610 »
Saturday I raked leaves, filled some bags with them and started filling up the truck to haul them to the dump. Sticks and trash are going in the trailer. Started figuring out what next years project is going to be. Probably a disk brake conversion. Gonna have to see how much money is left after paying to have the oak tree in the front yard removed.
hotrod ford
hotrod ford wrote:removed the grille, radiator support and disconnected all hoses and wires from the eng. should pull it and the tranny tomorrow to get ready to refresh the engine.
well today is my tomorrow and here is what i did:
http://i180.photobucket.com/albums/x115 ... 1256694225
mljjones67
Post by mljjones67 »
Nothing today but I got the sandblasted frame back and it looks good.
sport71
Post by sport71 »
I buffed my 68 aluminum grill.
marxtoys
Post by marxtoys »
unloaded the pile of firewood from bump trailer.
thought about un-hitching the car hauler from the pickup but didn't do it.
"Knowledge is Good." Emil Faber
