An alternative to Metal Ready
- spartman
Found out that the main ingredient in Metal Ready is Phosporic Acid.
If all you want to do is remove the rust you can either buy it from a school chemical supplier, ebay, or get a concrete cleaner.
If you have a home depot near by simply pickup the Pre-Cast Concrete Cleaner product made by Miracle Sealants.
The stuff from Home depot is acutally a little stronger than the Metal Ready.
Just thought I would throw this out and see what came back.
re: An alternative to Metal Ready
Yea, and probably 1/3 the price!!
Steve
69 F100 300I6
67 Mustang fb FE 431ci
72 Gran Torino Sport 351W
91 Bronco 351
69 F100 300I6
91 Bronco 351
por-15 is the same as industrial steel sealer, witch you can by at your local paint store it is also used on bridges to seal ! It is made the same catalyst and composites as por -15. After the bridge is prepped and painted the density is taken to see if there is coated to spec this is called hang time most steel workers know about this stuff !O and is half the cost at the local paint store!
- binder56jd
thanks for those heads up tips
jd
"Sell crazy someplace else. We're all stocked up here" — Jack Nicholson, As Good As it Gets
now serving #235
"the only way to believe in the American dream is to be asleep"--GC
How much easier it is to be critical than to be correct. - Benjamin Disraeli
now serving #235
- xxxtina63
Cool. So this stuff will actually eat off the rust? I suppose you have to keep an eye on it or do it in several stages. If I recall phosphoric acid will also eat through the metal if left on too long. Does this sound right? Has anyone tried it? Does it work well?
My FORDification Photo Album
- spartman
It will like all acids eat the metal completely.
The big thing with the phosporic does it a lot slower and safer than the hydrocloric or sulphuric acid.
I bought a bottle of stuff called rust eater at my local TSC and am trying it on an old rusty carb from a tractor.
The carb is all cast iron and was badly rusted inside and it seems to be working quite well.
Anyone done a price comparison on the steel sealer? Is it UV resistant? Colors?
Patrick
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
- flyboy2610
Are you supposed to wash it off before you apply the Por-15?
I thought after the Marine clean stage the metal wasn't suposed to be touched?
- flyboy2610
Yeah, I understand that the Marine clean needs to be washed off, but I geuess I should have clarified my question.
Does the Metal Ready need to be washed off, too? I can't find anything on the label about that. Or does the first application of Por-15 neutralize the Metal Ready?
- spartman
- flyboy2610
Ooops!
It was on the label. I missed it. My bad.
