floor pans
floor pans
Im lookin at possibly replacing my floor pans all together. Are they plug welded in or what? Should I go ahead and get both cab braces (left and right) while im at it? new rockers may come as well. What does everyone think?
How do you install them in my main question. If anyone has pictures that would be great.
re: floor pans
The factory floorpans are all one piece. If you have one side or the other that is rusted out, you have to cut out the rusty section and weld in the replacement. You can't buy a single piece section for the entire floorpan.
As for the cab braces, if they're rusted out, now would be the perfect time to replace them, while you're doing the floorpans.
re: floor pans
LMC has them....in fact, that's where I bought mine. However, you can do some price-comparison with some of the other vendors, if you wish, though I think they're a pretty standard rate between all of them. The first seven vendors listed on the LINKS page all show them in their catalogs.
- Galaxie64
I swear I saw someone who had eeither left or right Floor pan pieces. You'd have to cut but I am 99% sure I saw someone who sold ea. side seperate.
I think I found it in NDP pg. 216 R or L floor panel 29" wide $55ea. I also think I saw it online somewhere.
'68 F150 2wd
'72 F250 2wd Camper Special (400/C6/4bbl)
'64 Galaxie 500 (3524bbl/57K miles)
'92 Grand Marquis (mostly stock 4.6L)
'97 F150 (heavily modded 5.4L)
'48 F1 (Flat 6)
'51 F3 (Flat V8 )
'56 F350 (engineless)
** Chuck Norris has counted to infinity -- twice. **
'48 F1 (Flat 6)
'51 F3 (Flat V8 )
- Galaxie64
Looks from the pics and #'s that '73-'79 are the same floor panels as well. they also have the center piece seperate from the looks of it.
LMC seems to have them in pieces too but they cost twice as much. LMC pg. 22 But the price isn't twice as much I was looking at the pre '67s
'68 F150 2wd
'48 F1 (Flat 6)
'51 F3 (Flat V8 )
'48 F1 (Flat 6)
'51 F3 (Flat V8 )
- bluef250
re: floor pans
for whatever reason, that did NOT come up when i searched .
- FoMoCo
re: floor pans
I think I'm the only one here wondering why you wouln't rather get another cab considering you're in Mississippi. It may be my over-generalization that the south is over stocked with clean parts.
Nick
Nick
1969 F-100
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
