f600 gauge cluster
f600 gauge cluster
How hard are these to wire into a 67 f-250. The cluster I have has gauges not warning lights. Thanks for the help everyone!
- jor
re: f600 gauge cluster
Nothing to it. It's either a direct plug or close to it.
jor
jor
I am looking at two on ebay one is painted white and one is painted black with chrome they are both in pretty good shape. I would really like the chrome one though. Anyone know about how much $$ these should be? Also blue oval truck parts has a nice billet dash panel for $159.00 minus the gauges. Gauges range from $260.00 too $700.00 If I go that route classic auto meter gauges will look good in there. Plus i live right down the road from auto meter so I can get there help putting it together.Thanks all
- FoMoCo
I'll second the recomendation for the billit panel. I bought the 6 gauge set for my truck. You'll have to have a plastic bezel to cut up for the install. The billit need constant polishing here where it's humid.
Nick
Nick
1969 F-100
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
That painted f600-700 panel will go around $100.00 and the chrome one (it is VERY nice) will probably go $250.00 or higher.
The rewire is very easy.. about the only thing you have to change and reuse from your original cluster is the flasher wires and the flasher switch. Plugs into the top right and left corners of the harness plug.
Patrick
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
I found one, actually several, but the 67-72 I was looking at they wanted 75 for the entire cluster, guages and everything. There were a bunch of 73-79 f600's too but I wasn't sure if they would work.
69 F-100 2wd 360 cid C6
