I have checked the inline valve and it is functioning property. When it is off, you can't blow air through it. The temp selector cable is working correctly, fully shutting the valve off in the 'low temp' selection.
The doors in the heater box appear to be moving correctly. When I have the selector to the off position, you can tell the fan isn't moving any air, but there is still air coming from this area
Next time y'all go for a ride, feel down there with the heat off and tell me if y'all feel any air. It might just be that I live in Florida and it is hot as fire down here right now.
If I can't find a solution, I'm gonna have to bypass the heater core so I can stand to drive the truck.
Any help is appreciated!!!
