I was doing some investigation on radio fitment for my 68 F100 and now realize that I do not know how to even remove th factory radio.
With the posts protruding through the metal dash mounting ears which also block the radio opening, I'm not sure if I need to dig my way to it through the factory A/C unit, through the gauge/instrument cluster, or through the dash pad.......help!?!
Radio removal
- flyboy2610
re: Radio removal
If you can get the glovebox out, that's the best way.
re: Radio removal
If your A/C is the factory suitcase style, the one that extends up into the glovebox area, you probably still won't have room even after removing the glovebox insert. You'd probably be better off by pulling the instrument panel out and removing the radio through that hole in the dash.
- Clarko
Re: re: Radio removal
You will have enough room with the glovebox out and the factory a/c there. I've done it.FORDification wrote:If your A/C is the factory suitcase style, the one that extends up into the glovebox area, you probably still won't have room even after removing the glovebox insert. You'd probably be better off by pulling the instrument panel out and removing the radio through that hole in the dash.
Brian
![Image](http://www.fordification.com/board/Clarko-sig.jpg)
1969 F-250 Ranger Camper Special 465FE/C6 (waiting on AOD)
1988 Bronco 351W/AOD
1994 Bronco 351W/E4OD
re: Radio removal
Thanks guys....definitely better to have a strategy before tearing into things....
- flyboy2610
I KNOW that.... I just don't always obey myself!benm78 wrote:Thanks guys....definitely better to have a strategy before tearing into things....
![Sad :(](./images/smilies/icon_sad.gif)
