Horn bar wires
f26yrn04558-72
Horn bar wires
Post by f26yrn04558-72 »
Can any one tell me where the two wires from the horn bar go on the steering wheel 72 camper spec. I know one goes on the clip ont the right side, but I cant find where the one that looks like a spring is supposed to go. The bar is new, I wonder if their is a part missing or broken off the wheel?
they should both be just inside the wheel right in the center.
f26yrn04558-72
That's what I thought. But there is only one post to attach the one wire with the female plug. The horn works when the other wire is touching metal on the wheel, or the steering shaft. But there is no way to attach it.
FORDification
Site & Forum Admin
Site & Forum Admin
re: Horn bar wires
Post by FORDification »
That's the ground wire. It's not actually 'attached' to anything. It just inserts into the threaded hole in the steering wheel hub...the one you'd thread a bolt into to attach a steering wheel puller.
f26yrn04558-72
Thankyou! I had a feeling it went in one of those holes, I just didn't want to jerry rig it. (no offence if any bodys name is jerry reading this)
