Installing a cargo lamp
mjhaltom
Post by mjhaltom »
Has anyone out there installed a factory cargo lamp in a truck that never had one? I mean cut the hole in the cab and everything. Any comments or tips would be appreciated as I attempt this. Thanks
1989 Ford F150
1966 International Scout 800
1953 Chevrolet Tin Woody
jzjames
re: Installing a cargo lamp
Post by jzjames »
somewhere on this site is the diagram for cutting the holes for the new cargo light, but I cant find it.
Maybe someone can help. :?
FORDification
Site & Forum Admin
Site & Forum Admin
Post by FORDification »
bluef250
Post by bluef250 »
mjhaltom
Post by mjhaltom »
I bought the other one that was listed today :D
1989 Ford F150
rjewkes
Post by rjewkes »
is this something that a dremel and a cut off tool could do?
fuelly.com
tynall44
Post by tynall44 »
i did mine with a dremel tool :D :fr:
mjhaltom
Post by mjhaltom »
Where would I splice it into the wiring harness? I have the original harness that goes to the lamp, but I need to know where it plugs into the existing harness. Keep in mind my truck did not have this option.
1989 Ford F150
rjewkes
Post by rjewkes »
I beleive it runs off the same line/fuse as the cigar lighter and interior light. there should be behind the guage panel atleast one wire that has three openings in it bullet style. Two might already have a wire running from it but it is perm. power.
fuelly.com
mjhaltom
Post by mjhaltom »
Thanks, I'll check it out.
1989 Ford F150
i have a cargo light that is original. i went out and looked under the dash for you. most trucks i have parted out only had two wires going up through the pillar to the fuel and interior light. well my truck has three so the third wire has to be for the cargo light. i didn't try to look any further because i would have had to take my stuff apart in order to look more.
basically you need a wire going to the switch that has power. from the switch up to the light. maybe you could pull power from the three socket plug on the left side of the dash behind the cluster robert was talking about.
tynall44
Post by tynall44 »
i just hooked mine to the interior lamp and a toggle switch :D
dotcentral
Post by dotcentral »
How far down from the top, or some particular seam or bodyline does it need to be to locate it correctly?
