rubber flooring
- 67RED
rubber flooring
any one ever try these http://cgi.ebay.com/ebaymotors/65-72-Fo ... 8069409391 less than 20 miles from me.
steve
Life is 90% how you take it10% what you make it
- averagef250
I think that's the only style of ford floor mat offered. I've bought several from several different parts houses and they're all the same. Not nearly as nice as the factory floor mat, but beats carpet. The ones that he's selling in that auction are for the small hump trucks. I think just the 3 on the tree trucks were that way. If you have a 4 speed or an auto don't buy that floor mat.
- Sharkdance
re: rubber flooring
Instead of the mat Id recommend scuffing the bare floor of the cab and rolling on a gallon of Hurculiner.
It insulates, sound deadens, looks pretty good, and wears better than any mat for any price.
Did it to mine and love it.
- jor
re: rubber flooring
I'm with sharkdance. The Herculiner works out well although I intend to cover it "some day." Here's a photo.
jor
jor
- MadMaxetc
re: rubber flooring
Thats not a bad idea
That way you know what is there (not dirt or mosture under the mat)
I just might try that.
Dan
FORD Girl
Photobucket Pictures
FORD Girl
- Sharkdance
re: rubber flooring
Here is mine before I put the interior back together.
And a couple of the Hurculiner being rolled on.
The boy is my son. (11 yrs old then) and my primary helper for this project.
The pix were taken after the first coat. While we were waiting to roll the second coat.
The Hurculiner works out well. You can leave it as is or cover it with carpet if you want. And as MadMaxetc just said, you dont have to worry about moisture collecting and rotting out your floor boards. Especially if you do the bottom side of your cab too.
- MadMaxetc
re: rubber flooring
Looks good!
Dan
FORD Girl
FORD Girl
- averagef250
Looks good, but I'll still take a floor mat. Spray in/roll on bedliner/non-skid products wear alot quicker than a rubber mat will. If you don't drive the truck much it'll look good for awhile, but after 10K miles or so you'll see exactly where your feet sit and after 30K or so you'll be down to metal. I've got one of the above mentioned floor mats in a truck that I've put 160K miles on and the spots where my feet sit are only about 1/2 way worn through the mat.
I've never thought the herculiner/ line-X type products hold up as well as they claim and once it's damaged it's not easy to make it look good again without redoing the whole area.
With a mat you do still have to pull the mat up and clean under it now and then, but with a good prep and paint job on the floorpans you won't have rust problems.
Painting the underside of the cab with that stuff does the same thing as undercoat. Hides the rust and holds moisture in.
- 69F110
- Big D's 69
I just pulled out my rubber mat and it was still decent, but I prefer carpet over the mat.
