#01 - Jan. 21, 2007
How's your Ford truck parts knowledge?
FORDification
Site & Forum Admin
Site & Forum Admin
#01 - Jan. 21, 2007
Post by FORDification »
What is this part? I need to know the specifics, not just the general. In other words, don't just say it's a widget...I wanna know the specific application and year (if it varies). ;)
its a wheel spacer for the lug nut on a f600 and larger trucks. i am unsure if this includes split rims or not. i think the larger f7000's had split rims
71 LONG BED
re: #01 - Jan. 21, 2007
Post by 71 LONG BED »
Distributor hold down clamp for a small block, a 302 or 351. :D
Not sure what years it was used. 1971 for sure. I don't think it ever changed.
John Member #1549
Image Image Image
yeah dont i feel stupid
GT-Racer
Post by GT-Racer »
I thought it really was a widget, thanks for ruining it Keith. No it is a dizzy hold down but I am not sure the years either. I know that is an early one.
'67 F100 2wd shortbed - Beginning restoration.
351w, 5-speed, 3:70 gears (someday)
Drivin' a Chevy is Kinda Like wipin' before you poop, it just don't make no sense....:)
rjewkes
Post by rjewkes »
Small bock ford Distributor holdown clamp from 1969-89.
fuelly.com
Sharkdance
Post by Sharkdance »
I dont know what it is.......YET :P
But I dont think its a dizzy hold down. Way too heavy steel and waaaay too thick. Definetly not for an FE if it is.
fordman might be closer with it being a wheel clamp. But I dont know.
Sharkdance
70 F250 2WD 360/C6
390Nut
Post by 390Nut »
It's a grease fitting for the left-hand muffler bearing for a `67 F450 heavy-half ton triple axle dump.
:evil:
I've seen that item before, but, I think oldtimers is kicking in a bit (or maybe a very mis-spent youth is what's catching up to me) as I have no clue what it's for. :?
Paul
`69 F100 390 4spd driver
ICEMAN6166
Post by ICEMAN6166 »
it is a distributor clamp,
not for an FE
it is an earlier one because its cast iron but it is for a 289/302/351W at the least, and if you are counting only the 67-72 trucks , would be the 1st year you could get the 302 so 1970-72 302 is the correct application.
rjewkes
Post by rjewkes »
I was for sure that 69 was the first 302. I could be wrong on that though.
fuelly.com
FORDification
Site & Forum Admin
Site & Forum Admin
Well, I won't hold you to the correct years used on this one, but let's just say we don't have a winner....yet.
(Is it gettin' warm in here or is it just me?) :wink:
spartman
Post by spartman »
How bout a dizzy clamp from a 240/300 six banger?
no its not a wheel clamp it is for a dist. maybe its for a y block i dont know or its off a olds :lol:
AustinTom
Post by AustinTom »
Its a distributer retainer for a 302. it keeps the dizzy in correct timing and secure to the block. the left pic is of the underside, the right of the top and the concave curved edge goes toward the distributer. I'm not sure how much more specific one can be than that
69 F-100 lwb 240 Np435
95 F-150 lwb 4x4
http://s110.photobucket.com/albums/n85/ ... type=local
FORDification
Site & Forum Admin
Site & Forum Admin
:evil: Not yet! ;)
And it's definitely a Ford truck part.
