door
A_G
door
Post by A_G »
ok on my buddys 69 f100 the door doesnt seem to open on the driverside from the inside. You pull the latch towards you and it just seems to be nothing.
Is there some kind of rod in there that is broken. That maybe i can weld back up. This is the one of the MANY problems im addressing tomorow. And fixing.
Hes painting it. Im fixing it. He gets out of the POS 72 bug he was driving. And i get to use his lift when it comes time on OL blue
"The happiness of a a man in this life does not consist in the absence, but in the mastery of his passions"
~Alfred Lord Tennyson~
Caterpillar Diesel Haul Truck Mechanic
tynall44
re: door
Post by tynall44 »
does it feel springy when you pull it? if not they have a little tab that sticks out on the handle that works the door,,,,,, if it doesnt feel springy its prob a rod broke or come loose.....
A_G
re: door
Post by A_G »
can i weld the rod on low heat with a mig flux core?
sure its metal isn't it.
flyboy2610
Re: re: door
Post by flyboy2610 »
A_G wrote:can i weld the rod on low heat with a mig flux core?
If you're concerned about heat, use MIG. The gas helps cool the weld. And on something that size, I would go with .023-.025 wire.
