Install A/C?
cghstrojan08
Install A/C?
Post by cghstrojan08 »
I was wondering if it was possible to install a/c? I see there is an under mount unit on ebay? Would something like that work?
ROBERT
Member #1076
1968 F100 SWB 360
1969 F100 LWB 360 "Ol' Blue" - Sold
1976 F350 Trailer Special, Extended Wheel base, 460
http://s9.photobucket.com/albums/a75/cg ... ld%20Blue/
yes these trucks had a/c in them. mine has factory a/c but other trucks have had dealer a/c in them also. and some didn't have any at all. it was a option back then.
cghstrojan08
re: Install A/C?
So, do you just take out the heater core and throw in the ac unit? The one I am looking at is dealer added? Do I need no make holes for hoses?
ROBERT
Member #1076
1968 F100 SWB 360
TxCoyote
Post by TxCoyote »
I just bought the a/c system from old air and will install it over the next couple of weeks. Not too expensive considering it is a complete system, new and R-134.
Russ Rosenberg
67 Ford F250
68 Jaguar XKE
87 TVR 350i
74 Alfa Romeo GTV 2000
71 Triumph Stag (ford v6 conversion)
06 Saab 9-3 Sport Combi (company car)
if you buy the dealer air you do not have to remove the heater box. it stays in. the holes for the lines originally went through the center top of the firewall. it had a cover that went with it on the factory models. i have seen dealer installed ones that they have just drill 3/4 inch holes in the firewall and used the black butyl stuff to fill in around the holes once the lines are through.
