Coil wire
theskytoucher
Coil wire
Post by theskytoucher »
On the back of the ignition wat color is the coil wire? this is on a 68 F-100. It burnt up on the one side which i can see but i is light blue but there is no light blue coming out the other side!!! Please help!!!!
-Troy-
1996 Dodge ram 1500 4x4
1976 Ford F-150 4x4
Quando Omni Flunkus Mortadi
When all else Fails Play Dead
kid
Post by kid »
The wire goes Red blue to pink to Red Green as it passes through the connectors. The blue wire is accessories.
Red Blue at the switch. Pink at the resistor and red green inside the engine compartment.
