Led Lights
71Ford100
Led Lights
Post by 71Ford100 »
Can LED lights be wired in a series? I read somewhere that eac has to be wirded seperately and that wouldn't work for my bright idea I have in mind.
Lance Peters
'72 250 4x4 project,''71 F-100 daily driver,69 F-250 4x4 Crew, '68 F-100, '68 F-250 crew under restoration, '52 Dodge 1/2 ton overload, gazillion tractors and combines
rjewkes
Post by rjewkes »
The motor cycle guys have a relay that makes it possable to use them in a series.
aslong as one bulb in the series for flashers is a normal bulb that will draw enough to make it work the flasher fuse. In line is possable for solid lights that don't need to flash.
fuelly.com
adrianspeeder
Post by adrianspeeder »
Series wiring of LEDs is quite possible as long as at most one isn't put in line backwords.
rjewkes wrote:aslong as one bulb in the series for flashers is a normal bulb that will draw enough to make it work the flasher fuse. In line is possable for solid lights that don't need to flash.
An appropriately sized resistor in parallel with the LED's would serve the same function to create a load to trip a flasher.
Adrianspeeder
'08 F-250 Spartan Tuned 6.4L PSD ZF-6 4x2 XL, Reg Cab,
'02 F-250 Vin Diesel 7.3L PSD 4R100 4x4 XLT, Crew Cab,
'97 F-150 Dad’s last truck 4.6L M5OD 4x4 XLT, EX Cab,
'79 F-150 Homebrew Dually 351M C6 4x2 Lariat, Reg Cab,
'71 F-100 Bump 302 4x2 3/tree Stepside Custom, Reg Cab,
'66 F-250 Slick 352FE 4x2 3/tree Custom Cab, Reg Cab,
Broncos: '94 Grandpa’s mint daily driver XLT 302 E4OD,
'92 Momma’s daily driver XLT 302 M5OD, '88 OJ XLT 351 C6, '84 Mint! Lariat 351HO C6,
USAF TSgt C-17 Aircraft Maintenance Flying Crew Chief & Flightline Avionics Craftsman
