Factory dual battery setup question.
tazzman68
Post by tazzman68 »
I have a 76 parts rig that I am stripping and it has a factory dual battery setup, does anyone have a wireing diagram of these things? I was considering moving it over to the 67 if I can figure it out.
Thanks in advance as always.
layedout72
re: Factory dual battery setup question.
Post by layedout72 »
mine came standard with rubber tie downs, extension chord jumpers, and a crusty sock.
heep70
Post by heep70 »
I have duals but not factory. What isolator do you have? Mine is a three post. The center stud is the alt, the left is primary and the right batt is secondary batt.
I am also running a one wire alt so that might not work the same as what you got as far as the alt post on the isolator.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
Fossil Dawg
Post by Fossil Dawg »
Greg, anyway to post a pic/diagram of what you have?I want to run/use one on mine, appreciate the help. :thup:
Fossil 8)
The ONLY true thing WE OWN and have to GIVE is our WORD. I did what others did not want to, and became what others could not, now the best "REVENGE TO WAR" is to live the best I can.
heep70
Re: re: Factory dual battery setup question.
Post by heep70 »
Fossil Dawg wrote:Greg, anyway to post a pic/diagram of what you have?I want to run/use one on mine, appreciate the help. :thup:
Fossil 8)
A one wire or dual batterys?
Greg
Fossil Dawg
I want to run dual batteries and will probably run a single wire setup also
thanks.
tazzman68
Post by tazzman68 »
You ask what isolator I have, from what I can tell it runs over to a 3 post solenoid, and there was a 4 post on the other side for the ignition system. Does this sound about right/ or am I missing a piece of the system?
heep70
Post by heep70 »
Here are a few pics of the one-wire conversion as far as what to do with the wire harness.
There is also a pic of the isolator I have. Tazzman, as far as what you have I beleive it is the three post. Is the center post wire going to the alt and the other two going to the batteries. There is a pic of my isolator below.
Greg
Fake Name
Post by Fake Name »
I used a big red marine-type isolation switch and change between batteries every month. Seems to keep it clean and simple. I also changed to a 135 amp Powermaster single wire alternator. Luck y for you, Greg took pictures of his setup, because I just started pulling wires out until I got only what I needed.
fn
1970 F250
2011 KTM 990 ADV
2003 KTM 525EXC
mr.skaggs
Post by mr.skaggs »
very clean set up!!! mine is different . mine goes to a relay just before battery and stops.are there others on here that can post similar wireing pics for non single wire setup??
69 ranger cs
i have a '69 f-250 camper special that im putting back to orginal condition.it is taking a long time to do but it is my hobby..this website has been of great value on looking for the correct parts and i have came across a very good way to remove rust from parts without damage to the part ..it takes time but no abrasives to wear off the numbers or castings!!
