Little round chrome thing. WTF is it?
RTG_RACING
Post by RTG_RACING »
ok i found this thing on the D/S lower corner of the dash. Looks like some kind of light. I have spent most of the day surfing the web trying to find out what it is. Any help?
FORDification
Site & Forum Admin
Site & Forum Admin
re: Little round chrome thing. WTF is it?
Post by FORDification »
Why waste that much time when you could've had an answer here in just a few minutes? :wink:
That's your brake warning switch light. Your front brake circuit and rear brake circuit are plumbed into a distribution block on the frame, which also houses a pressure valve. Normally both brake circuits are balanced in pressure, and the light stays off. However, if there's a loss of pressure in either the front or rear circuits, the valve goes off-center and the light comes on, to alert you of brake problems.
wt4speed#2
Post by wt4speed#2 »
Brake warning indicator,comes on as a warning t6hat some thing is wrong with brake system
Tony B.Image
DFW Area
"Someday...
I hope you to get the chance,
to live like you are dying"
Member#'s 236 & 403
Úlf the Comedy Sidekick
wt's ride
thebucket
68F250
Post by 68F250 »
Ever touch that little light after it's been on for awhile? :cry:
Barry
Heavenlyfire
Post by Heavenlyfire »
:lolprev: :lolprev: :lolprev:
flyboy2610
Re: re: Little round chrome thing. WTF is it?
Post by flyboy2610 »
68F250 wrote:Ever touch that little light after it's been on for awhile? :cry:
Nope. I'm crazy, not stupid.
Jake11
Post by Jake11 »
Keith's right on. You probably coulda known in 2 min's 8)
wt4speed#2
Kinda burns huh!!!
Tony B.Image
DFW Area
"Someday...
Member#'s 236 & 403
wt's ride
thebucket
MadMaxetc
Post by MadMaxetc »
My light comes on if the e-brake is on too.
Dan
FORD Girl
Photobucket Pictures
FORDification
Site & Forum Admin
Site & Forum Admin
MadMaxetc wrote:My light comes on if the e-brake is on too.
What? Are you saying that the light is off when you e-brake is off, but that the light comes on when you apply the e-brake?? That shouldn't be, since there is no direct connection between the e-brake and that light. :?
The only thing I can think of (and this is a stretch!) is that when you apply the e-brake, the resulting action of the e-brake cable pulling on the rear brake shoe puts a very small amount of pressure on the hydraulic portion of rear brake circuit, and if the valve in the distribution block is already slightly off-center, it might be just enough to trigger the warning light. I'll bet if you were to bleed the front circuit just a tiny bit to re-center that valve, the warning light wouldn't come on anymore when you apply the e-brake.
67F250CS
Post by 67F250CS »
Its a space time continum warpage indicator light. When its on it means that time has sped up a milisecond.
The only sure fire way to turn it off is to buy the special black tape and cover it or just unplug it.
Just kidding the advice given above is right. We had a comical thread about this very same subject not too long ago. If you use the search function and put in brake light indicator you should find it. Good for a few laughs.
1967 F250 Camper Special
10MPG with key off, in neutral and going downhill!
RTG_RACING
67F250CS wrote:Its a space time continum warpage indicator light. When its on it means that time has sped up a milisecond.
If I had knowen what to search for I wouldn't have had to ask. :D
mrsnicks
Post by mrsnicks »
Kinda sorta off topic.. Does anyone make a replacement red lens for the light?
My red plastic lens is all burnt through.
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
MadMaxetc
Post by MadMaxetc »
Ya the Light comes on when the e-brake is set.
I kind of like it that way. When you do the Disk brake swap how do you wire the light back in? Or do you?
I want it to work like it is now after I do the swap.
sorry for the Hi-jack. It is kind-of relevent. :)
Dan
FORD Girl
Ranchero50
Post by Ranchero50 »
That's kind of neat about the ebrake. May have to put a switch on just to do that...
Jamie
