Mech Stoplamp Switch Help
- F10YRB12118
Does anyone have any advice for me on how to get my Stoplamp switch to work? After taking a couple months off from my 67 F100, (forced exile to Texas for work) I'm back at trying to get my brake & signal lights working.
I have checked all my wiring and the switch, they all work fine. When I bypass the switch, the brake lights work, but I just can't seem to figure out how this darn switch mounted to the brake pedal and push rod. It seems to only mount one way and no matter how many ways I try, I just can't get the switch to work.
Does anyone have a link to a diagram or picture thatt could help me?
Any and all help is appreciated!
Yours, Sean Malis
Yours, Sean Malis
Sean
1942 Chevy Truck, 1.5 Ton, G503
1967 F100 352 LWB Custom Cab
1969 Bronco Wagon 302
1972 F100 360 SWB 4x4 XLT
1972 F250 360 LWB Parts Donor
1973 F250 360 LWB 4x4 Donor?
1979 F250 460 Parts Donor
- F10YRB12118
re: Mech Stoplamp Switch Help
Anyone have picture of the correct set-up for the stop lamp switch on the pedal?
Sean
- 71PA_Highboy
Hi Sean,
I don't have pics, but if you want to get a better view, find any 65-73 Ford car and look at them - Broncos too... Since you are in Cali, there should be a Mustang show near you every weekend, so go look for a Mustang for sale and crawl under the dash.... the visualization will REALLY help..
BTW, if you aren't using a new switch, get one... they can go bad functionally in the car and work on the bench because of the different forces applied.
hth,
eric
hth,
eric
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1 Lincoln Mark VIII
- ratfink
Sorry the second one is a little blury, but it is early and I was standing on my head. Hope these help.
Ratfink
Dennis
1968 F100 Ranger 390/ C6 (Mine again)
2008 Toyota FJ Cruiser Sandstorm
2007 3500 4X4 Dodge Cummins
Idleness is the mother of all vices.
- ToughOldFord
There's your problem, RF, you're not supposed to stand on your head, you're supposed to flip the truck over.
- 68F250
He's looking for a pic of a '67 switch. Sorry don't have one but didn't we have a thread recently that went thru this w/ pics? I can't find it.
Barry
- ToughOldFord
The '67's different I take it. I'll try to get my camera out and get a pic or two of my 67 a little later.
- F10YRB12118
Eric, Dennis, Barry & ToughOldFord,
Thank you all for the advice. I look forward to the pics of the 67 switch. I wish that I had the 68 switch, it would be a lot easier. In fact I went to the pic-a-part and ripped the whole assebly, pedal and all out of a 68 so that I might solve my switch problem.
I just don't want to replace everything with 68 parts. The switch problem might be fixed, but getting everything to line up might not work. Plus, it is a lot of work to take everything out and put in 68 parts just to fix a switch.
I have been back up under the dash tonight trying to figure this thing out, no luck. The switch appears to attach to the end of brake push rod and a bolt goes through the switch, push rod and brake pedal. That is all I can figure out.
I did buy a new switch and it just like the one I found in my old truck. I will use it when I finally figure out how to install this crazy thing!
Thanks again for all your help. I look forward to the pics.
Yours,
Yours,
Sean
I have a couple pics, but they're not the best. Hopefully these will help:
- ToughOldFord
Hope these help, unfortunately the L/S is kind of hidden by the steering column.
- F10YRB12118
Keith,
Your pictures provided me with the key to fixing this problem!!! You have saved me a lot of frustration, especially since I'm a beginning shade tree mechanic.
The key to getting this fixed was the bolt and nut. Mine had a hardware bolt installed. I had found the original bolt behind the seat when I first cleaned the interior out. I didn't know what it went to but saved it just in case. Now I know what it was for. My original bolt looks just like the one in your pictures.
My brake light problem is now solved and now I just need to get my turn signals to work.
Thank you everyone!!
Sean
- F10YRB12118
ToughOldFord,
Thank you for the photos. This are great. Now I have a reference for running my wires.
Thank you all so much for this help and guidance. I am ellated over having working brakelights!
Yours,
Yours,
Sean
- 68F250
Good deal! We share your joy.
Barry
that's awesome, the same thing happened to me when I first got my truck. at first i thought it was for the original am radio
68 f250 "highboy" frame
67 np435 trans
68 dana 24 t case
67 dana 60 rear w/track loc
76 dana 44.6cf front w/DPC and heavy duty hubs
70 ford body w/rust incuded!!!
R.I.P. the 87 subaru GL wagon "the traildancer"
67 np435 trans
68 dana 24 t case
