For our trucks, are these the standard bolt heads, or is it an allen wrench or torx/star fasteners? I need to get some hardware, the p.o. removed it all.
I might look for 88-98 (or whatever the range is) GM truck 3-point belts, I'm hearing they can be made to work in our trucks fairly easy. I think those take torx bits, but anyone know for sure?
seat belt fastening hardware
- 68F250
re: seat belt fastening hardware
Is there a pic somewhere?
Earlier trucks used a standard bolt head while later trucks used a torx head, other than that the bolts are the same. I forget what year the change happened.
Barry
- flyboy2610
My '69 has Torx head bolts. I don't know what size they are, though.
They might not be original, I don't know for sure.
- MadMaxetc
67 has standard heads, but it is an odd bolt. (shape is funny)
Dan
FORD Girl
Photobucket Pictures
FORD Girl
- RebelRider
Tim,
Bolts for '67 seatbelt are about one and 3/4" long with a 1/2" shoulder. Thread is 7/16x20. Head is 13/16. Here's pic....
- 71 LONG BED
I've got all the hardware out of a '67. You can have it if you want it. PM sent.
John Member #1549
- 68F250
How'd we get onto 67's?
Anyway the bolt pictured is the early style w/ the standard head, same as my '68.
Barry
Thanks for the info. I need a few other odds & ends so I'll hit pull a part this weekend if the weather cooperates.
