floorpan welding - gas tank concerns
MAK
Post by MAK »
I just pulled out my seat and belts and was getting ready to do some cutting and prep work to begin some patching on my floor pans and got to thinking about the gas tank. Hadn't thought about the proximity to the in-the-cab tank until now. Repairs are all toward the front of the cab and a couple small patches at the sides right over the floor supports.
I guess to be safe I'm going to have to drain and pull my tank?? :?
I suppose if that's the case I'm going to have to put this off until I can be off the road longer. Not like this is my daily driver but I still tend to need it most weekends.
jzjames
re: floorpan welding - gas tank concerns
Post by jzjames »
Should be easy to pull out the tank. Take like an hour, and then you can work clean. :D
wt4speed#2
Post by wt4speed#2 »
Hell I never even considered that I just welded away .Hmmm lucky I'm still here....
Tony B.Image
DFW Area
"Someday...
I hope you to get the chance,
to live like you are dying"
Member#'s 236 & 403
Úlf the Comedy Sidekick
wt's ride
thebucket
69bumptruck
Post by 69bumptruck »
:lolprev:
David, owner of:
1969 F100 SWB (restoration in progress)
http://www.cardomain.com/ride/2317125
gonzalo medina
Post by gonzalo medina »
Take that sucker out :eek:
wt4speed#2
Too late I'm done . Still got the garage and the truck . :doh: . I never thought about . I drained mine dry when I put it in the garage and it has been sitting in there nearly 20 mnths(prior to any welding) . I dont know if it will ever see gas again . And i welded all around the tank, I guess it never "SPARKED" any concern to me. But I will consider the area shuold anymore welding be done on the truck .
Tony B.Image
DFW Area
"Someday...
Member#'s 236 & 403
wt's ride
thebucket
averagef250
Post by averagef250 »
Probably not the smartest thing, but I never seam think about the gas tank. Of coarse, taking the tank out just makes sense, but if it's full, or mostly full I'm pretty sure I'll just leave it in there.
Ever throw a match in a bucket of gas? It's alot worse to throw a match in an empty bucket of gas.
For me, it's always the things I would never in a million years expect to try to kill me that try to. I just filled my oxy/acetylene tanks (got the big ones) and I'm doing some exhaust work on the rack when an explosion knocked me right on my ass! Before I come to my senses I hear a huge crash and thud and see my giant acetyle tank hitting the ground and toppling over (wasn't even hooked up yet). The buttheads that filled it left the tiny pipe plug in the bottom of it loose and it was leaking acetylene, the weld sparks lit it up and turned the bottle into a rocket. Must have launched it 5 or 6 feet in the air.
I ran my legs over working on my '70 once. Not going to elaborate, but it was real stupid. I was fine.
merclover
Post by merclover »
sue em buy another truck hahaha
68 mercury m-100 brand new 390/c6
merclover
Post by merclover »
i never took my tank our n i just finished my floors
Kurt Combs
Post by Kurt Combs »
Make real certain you don't strike an arc on an empty tank or mostly empty tank! Either remove it, or fill it clear up. I heard a story of a guy who struck an arc on a full tank in a car, he lived to tell about the stream of burning gasoline because the tank was full. The car was completely burned, but he lived. All that said, I did mine with the tank in, but I did a really good sniff test before welding.
Kurt
1972 F-250
FLATBEDFORD
Post by FLATBEDFORD »
A full tank should be less of a hazard than en empty one. The fumes in a empty tank are more likely to explode. Didn't they determine that a the TWA flight 800 crash off in Long Island, NY about 10 years ago was due to fumes in an empty fuel tank?
Steve
1970 F350 DRW Factory 9' Platform/Stake, 360, T18.
Passed on to new care taker July, 2013
My Photo Gallery
http://s115.photobucket.com/albums/n298/flatbedford/
averagef250
Not sure I believe all that crap. Jet fuel is refined diesel with icing inhibitor. It's about as explosive as a bad fart, but I guess strange circumstances can make unusual things happen.
When I was in the Navy I spent a lot of time in the ship's oil lab "testing oil" (goofing off). We'd fill soda cans with JP-5 jet fuel and light them to keep the oil lab warm in cold climates.
FLATBEDFORD
They said it was fumes 'cause the tanks were empty. Maybe it was a bomb and they kept it secret?
Steve
My Photo Gallery
foghorn
Post by foghorn »
Its true a empty tank will explode faster than a full one will. More fumes and air space to expand in.
Foggy 8)
Work is for people that dont know how to fish
ima71 trucks are older
Post by ima71 trucks are older »
I've tested it with what I thought at the time was a good arc welder simulation.
Full tanks burn, almost empty tanks explode. A metal gas can or old tank full of fuel with a bug zapper on top of it will catch on fire after a few bugs die and it sparks a few times. The same tank with only a gallon or so in it will send bug zapper and parts of the tank into the neighbors driveway and the sherrif shows up.
Somehow I survived being a drunk teenager.
68 F100 soon to be on an 80's 4x4 frame and 300-4spd
69 F100 300-4spd
78 F150 300-3spdOD
