seatbelt hole
JB4020
seatbelt hole
Post by JB4020 »
I have the julianos seatbelts to put in my '71 f100 and when i pulled the rubber plug out in the back pillar i didnt see any threads. Do you usually tap that hole or is there something else you take out. Thanks
MadMaxetc
Post by MadMaxetc »
My 67 has a nut welded on there. Are you sure there are no threads?
Dan
FORD Girl
Photobucket Pictures
JB4020
re: seatbelt hole
Post by JB4020 »
I popped the rubber plug out and there is just a hole. Do i need to pop something else out?
MadMaxetc
Post by MadMaxetc »
No. There is a peice of metal a little further in that has the nut welded to it. Maybe they forgot to weld that on in your truck ?
Dan
FORD Girl
JB4020
re: seatbelt hole
Post by JB4020 »
Has anyone just tapped that hole? I wasnt sure if it would be strong enough
FORDification
Site & Forum Admin
Site & Forum Admin
re: seatbelt hole
Post by FORDification »
All the trucks I've parted out had a threaded insert, but I have heard of some owners over the years who have reported no such insert. I don't think I'd wanna trust just hooking the belt mount to the sheetmetal, though.
I'm kinda in the same boat as you though. I want to add 3-point belts to my choptop, but the threaded hole for the upper mount was located in the section of the roof that got removed when the cab got shortened. So I'm planning on welding a nut to some plate steel and then fitting it in up between the inner and outer cab walls, just like a factory installation.
jzjames
re: seatbelt hole
Post by jzjames »
I also have always heard reports of some cabs with no threaded seat belt mounting holes, and that a tapping was going to be required into that solid slug. The whole is likely the correct size for a ??? size tap....
JB4020
re: seatbelt hole
Post by JB4020 »
I could not find threaded holes on either side so i decided to tap them and a 3/8 16 tap fit perfectly. I just hope its strong enough with a 3/8 bolt instead of the bigger one they give you. Thanks
