Emergency flasher switch location
FORDification
Site & Forum Admin
Site & Forum Admin
Post by FORDification »
I recall a discussion a long time ago (at the Dark Side) about the different locations of the emergency flasher switch, but I didn't save the info, and I really want to include this on the Identifying '67-'72 Pickups page, so in the interest of getting it right, I defer to you all.
I seem to recall the discussion as determining that the flasher switch was located in the glovebox from '67-'69, except on trucks equipped with factory A/C, whereas it would be located under the dash either to the right or left of the steering column. Starting in '70 the switch was moved up into the dash in the middle spot of the three available mounting holes.
Does this sound right? Does anyone have a truck with a switch location that doesn't go by these rules?
1968F250LWB
re: Emergency flasher switch location
Post by 1968F250LWB »
:shh: DAMN YOU KEITH! :cry: Not this can of worms again. :lol: My 68 has it in the glovebox.
Russell
"If you can't be kind, at last have the decency to be vague."
My Photo Gallery
FORDification
Site & Forum Admin
Site & Forum Admin
:lol: Yeah, I know...I'm a maschocist. :twisted: It's just that I've noticed quite a few people on E-bay selling the later-style flasher switches, saying it will fit all years ('67-'72), so I thought I'd better include something on the ID page to TRY to clarify things. I do remember there being a lot of confusion on this, but I think it's time we try to get it right....well, as much as possible, anyway.
willowbilly3
Post by willowbilly3 »
Ah, yes the old migrating E-flasher switch. It seems like tha last discussion I was part of at the Dark Side ended up with a couple anomolies.
jor
Post by jor »
I've had two 67s. Neither had A/C and both had the switch in the glovey.
jor
68F250
Post by 68F250 »
Here's an in-dash flasher switch, notice the part # starts with a D0.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 98738&rd=1
This makes me believe '70 was the start for the switch in the dash.
bryantracing460
Post by bryantracing460 »
My 72 has the switch in the glovebox.
Jeremy
Drive It Like You Stole It.........NO FEAR!
69 F-100 swb 2wd 460 C-6. 86 F-150 super cab 2wd 302 AOD.85 Bronco 4wd 300 AOD.
http://www.myspace.com/bryantracing460
68F250
Post by 68F250 »
Should have reworded that!
This makes me believe '70 was the start for the posibility of the switch in the dash. It could still be in the other usual locations. :)
dotcentral
Post by dotcentral »
My canadian built 70 has it under the dash, not sure which side of the column. I think the right side. I will edit this post once I can verify.
BigRedTruck
Post by BigRedTruck »
my 69 has it under the dash on the right side.
69 F-100 2wd 360 cid C6
FORDification
Site & Forum Admin
Site & Forum Admin
Those of you with '70-'72 trucks who also have it under the dash: it seems (so far) that Ford put it there when they ran out of room on the dash, because of a choke, rear cab light switch, lighter, etc. Since there was only so many holes to mount things, something had to give, and since they already had the little underdash mounting bracket (from the '67-'69 trucks), it seems that the flasher switch was the logical choice to get relocated.
4x4x4crewcab
Post by 4x4x4crewcab »
I COME IN PEACE---I was just wondering about all this so I will post what is written in my Ford parts catalog----Illustration shows 2 simple photos
1) Ill---67-69 (in glove box) photo has no mention of a/c or non a/c-
2) Ill---70-72 (indash) photo again makes no mention of a/c or non a/c equipt vehicles.
Remember these Ill. do not give complete part numbers only the basic number of 13A350 and a sketch of the typical system used in these trucks for these years.
Now for the text information. A total of 4 different part numbers are listed as follows
67 F100/F350
68/69 F100/350----exe. with A/C part# C6AZ-13A350-D
This above number should have stamp I.D of C8TB-10C841-B
68 F100/350 with A/C "Emergency flasher" part# C8TZ-13A350-B
This above number should have stamp I.D. of C8TB-10C841-A
69 F100/50 with A/C "Emergency Flasher" part#C9TZ-13A350-A
This above number should have stamp I.D. of C9TB-10C841-A
70-72 F100/350 part# DOTZ-13A350-A
This above number should have stamp I.D. of DOTB-13A350-A
I wish I knew the exact differences but I dont. Maybe all of us can check our switches and come up with a photo to put by each number
Mark
1970 Ford F-250 Crew Cab 4x4 short box
1969 Volkswagen Karmann Ghia
1999 Ford Windstar
1983 Chevrolet Silverado p/u
1990 Lincoln Town Car
1998 Lincoln Town Car
Does your truck need emblems? Check out http://www.onceuponapart.com
flyboy2610
Post by flyboy2610 »
My '68F100 has it in the dash to the right of the steering column.
69F110
Post by 69F110 »
Both 69's and the 70 I have owned all had the glove box switch.
Steve Davis
Pastor and U.S. Army Retired
DuckRyder
Post by DuckRyder »
My 72 has a push/pull switch in the dash.
