Instrument Cluster Removal
delaire
Post by delaire »
I have a '70 F250. I want to trace a short and would like to pull the instrument cluster. There are 8 screws on the frame of the cluster. Does anyone know how it comes out and if there are any pitfalls. Thanks.
wt4speed#2
Post by wt4speed#2 »
Just eight screw, unscrew the speedo cable and pull it out far enough to either access the wires you need .Or unplug it pull it out and reposition it and plug it back in should you need more access and the panel connected to trouble shoot your needs.
Tony B.Image
DFW Area
"Someday...
I hope you to get the chance,
to live like you are dying"
Member#'s 236 & 403
Úlf the Comedy Sidekick
wt's ride
thebucket
delaire
re: Instrument Cluster Removal
Post by delaire »
Thanks for the info.
jor
Post by jor »
One other piece of advice: Disconnect your battery before messing with the instrument panel. If a hot wire is bare in there, you can fry your harness in an instant.
jor
