1. Lights on dash barely light up.
2. Both turn signal lights and high beam light stay on.
3. When I turn on my left turn signal, the right signal light bulb flashes.
4. When I turn on my right turn signal, both flash along with the high beam indicator.
5. When I turn on my hazard lights, nothing flashes.
6. When I turn on my high beams, the light goes out.
7. Fuel gauge showing that I have a very full tank of gas. I don't. I have a little over a half a tank.
Keep in mind that this is only happening in the instrument cluster. I checked all lights on the outside and they are working.
I did have a hard time with the odometer cable this time so it is possible that I knocked something loose. Oh and since we are on the subject of the odometer, I am not getting accurate mileage. I drove the truck two weeks ago probably 30 miles or so. It shows that I ran around 60. That can't be right because I only drove it to work which is 8.5 miles from my house. Went home for lunch and back, then drove it home. That's 34 miles.
Sorry about the rant. I'll shut up now.
