R/Rear brake,tailight and turn signal will not work
Cowboy34
Post by Cowboy34 »
I have a 67 Ford F100 2wd and the right rear tailight,brake light and turn signal will not work i replaced the whole assembly because the origoanle one was not working and after i switched them out, i found a wire that was not hooked up to anything and i tried putting a jump wire from the right side lights to the left side and the right side still did not work>>can any one help me??
ToughOldFord
re: R/Rear brake,tailight and turn signal will not work
Post by ToughOldFord »
You have a ground problem. Run a wire from a clean spot on your frame to the light assembly.
MadMaxetc
Re: re: R/Rear brake,tailight and turn signal will not work
Post by MadMaxetc »
ToughOldFord wrote:You have a ground problem. Run a wire from a clean spot on your frame to the light assembly.
:yt:
there should be 3 wires in the plug (white, brown, green) and one ground wire (black).
Dan
FORD Girl
Photobucket Pictures
FoMoCo
Post by FoMoCo »
You may want to check out my thread on the signal cam fix/replacement I had the exact same problem of my 67. The power for the brake lights and signals goes through a very weak set of contacts behind the steering wheel. Most of them melt over time and lose connection. Check to make sure you have power going to the brake pedal switch. This is the switch located under the dash where the brake pedal pivots. Next, make sure power come out of the switch when the brake pedal is pushed. If that checks out good then pull the steering wheel off. There are two gold colored rivits facing you on the white plastic signal assembly. The wire on the right should have power to it when the brake pedal is pushed. Look closely for the plastic to be melted slightly. If the wire on the right, under the wheel, is getting power then find the corresponding wire that the brake light power jumps to. I think on the 67 the power jumps from a solid dark green wire over to the orange w/blue strip wire. It makes the transfer by way of the plastic signal cam.
Hope this helps
Nick
1969 F-100
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
ToughOldFord
Right, that was my first thought too, but Cowboy said his taillight also isn't working and tail lights aren't run through the turn signal assembly. And when he ran a hot from the working side to the dead side and it still didn't work that leaves the ground as the only culprit left. Assuming of course the bulb and socket is good. :thup:
