homemade gauge cluster pic, (hope this works)
It clicks through, but if you meant to have the image on the page, then no, it does not work.
Patrick
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
re: homemade gauge cluster pic, (hope this works)
Bummer. Not sure how to make it appear. Thought I followed instructions correctly. Oh well, you get the picture. Total cost was about $140 which includes new "equus" gauges, two green indicator lights for blinkers, and one blue for bright lights. Ordered gauges online and bought indicator lights at radio shack. I cut out the middle of my old cluster housing. Made a pattern out of poster board for the gauge panel. Had some aluminum diamond plate laying around that I cut the holes in useing hole saws. Painted it all gloss black and I think it came out pretty good. Not bad for $140 ish with new gauges I think.
- FormerMarine1981
That looks sharp. How much time did you put in on that?
What we do in Life, Echoes in Eternity
- MadMaxetc
Re: re: homemade gauge cluster pic, (hope this works)
just take out the spacesChicken wrote:Bummer. Not sure how to make it appear. Thought I followed instructions correctly. ...
Code: Select all
[img]http://www.mypicshare.com/thum.....smrgrh.jpg[/img]
Code: Select all
[img] http://www.mypicshare.com/thum.....smrgrh.jpg [/img]
Dan
FORD Girl
Photobucket Pictures
FORD Girl
- 71 LONG BED
Dan's right, just take out the spaces and it'll work.
That gauge panel looks great, too! Nice job.
John Member #1549
- kaptnkaos
Hey Chicken...
That looks sweet...
What did ya use for the face plate?
KaptnKAOS
That looks sweet...
KaptnKAOS
The face plate that the gauges actually mount to is aluminum diamond plate. It was some scrap that I had laying around from an old aluminum truck bed tool box. I used diamond plate b/c I've got it on some other little pieces and with it being aluminum it's really easy to cut. It didn't really take that long to make, without painting and wiring everything up, probably could do it again in a few of hours. The hole saws make everything go really fast. First I cut the plate to the right length and width. Marked my center points, length and width, then measured for correct placement of the gauges, marked where to drill the holes and then drilled them. I then used some plumbing solder pressed against the old part to get the curves right for the ends, set the wire on the alum. and traced it out. Used a grinder with a cutting wheel to do the length and used a jig saw for the ends. Did some filing and sanding to make it look pretty. Also drilled some holes around the perimeter to screw it to the old plastic panel. It really was not that bad to do. Hardest part was getting the curved ends right.
- kaptnkaos
Hey Chicken...
That's cool ... you did a great job.
I was curious about the speedo...
No problem seeing how the other gauges work, that's pretty straight forward.
How about the Speedo?
Did you have to do anything to make that work right?
Thanks,
KaptnKAOS
Thanks,
KaptnKAOS
No, no probs with the speedo. Original cable screws right in to the back just like on the original speedo (though I did purchase a new stock cable from lmc), but no probs.
- MaxKlinger
Nice job! What gauges did you install? Fuel level, Speedometer, Oil Pressure, Water Temp, Volts? Do you have a tachometer in the cab?
Tony
'05 Focus ZX4 ST - 2.3L, 5spd
The brand is equus. Volt, fuel, speedo, oil, water. No tach.
nice work...
