headliner chrome
headliner chrome
Is the headliner trim the same for all years? I have a '72 and have found the trim from a '70. Just want to make sure it will fit.
re: headliner chrome
It'll fit. Should be the same on all from 67-72
1989 Ford F150
1966 International Scout 800
1953 Chevrolet Tin Woody
1989 Ford F150
'67-'69 are a 6-piece set and '70-'72 are a 4-piece set. The early trim has separate rear corner pieces (accounting for the extra 2 pieces) whereas the newer trim has the rear corner brackets as a integral part of the side pieces. The trim sets are interchangeable for all years though.
Kieth you sure are up on these trucks. I would have said that they were all the same myself. Which trim level got the chrome? I have a set of the chrome ones I am thinking about using.
clint
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
Usually the way it goes is that the cool stuff like this chrome headliner trim would've been standard in the top-end trim levels (all Ranger and Ranger XLT) and optional with the middle trim levels (Custom Cab and Sport Custom). The base models would've gotten the painted versions.
