F-600 cluster
- averagef250
F-600 cluster
Did Ford ever use a tach from the factory in an F-600/500 cluster? Was thinking they might have used a shaft driven tach maybe? It'd be something cool for me to watch out for anyway.
I think I'm going to go with the chrome big truck cluster in my '70. I recently found a mechanical tach drive setup for the cummins. Think it'd be cool to mate that with a factory Ford diesel tach if they ever made one in the 600 dash.
- customcrewcab
re: F-600 cluster
there was somone here who had a mechanical driven tac out of a f600. i will look and see if i can find where it was posted ![Thumbs up :thup:](./images/smilies/icon_thumright.gif)
![Image](http://www.fordification.com/images/forum/ty.jpg)
- averagef250
re: F-600 cluster
Yes, most of the panels I've seen had factory tachs in them...and yes, they were mechanical units driven off the distributor. Unfortunately an FT distributor won't fit an FE, so you'd either have to buy an expensive mechanical-drive distributor or convert it to electric. There's a member here who did just that (the conversion).
However, these tachs only go up to 4K, which might be OK in a lightly-driven street truck, but otherwise I would think you'd want something that read a little higher in the RPM range.
![Image](http://www.fordification.com/board/tachNOS_C3TF-17360-A2_01.JPG)
![Image](http://www.fordification.com/board/F600panel_w-circuitboard_03.JPG)
re: F-600 cluster
That wold be perfect for the 4bt conversion
re: F-600 cluster
Try to find any F or C 600 or larger with a 477 or 534 in it and there should be what you want. Most Truck Junkyards should have a few. Old Fire Engine, or Utility Company Units from the 60s to the 90s.
Fred
Fred
Re: re: F-600 cluster
Hmmm....you're absolutely right!mljjones67 wrote:That wold be perfect for the 4bt conversion
- averagef250
Kieth you're the man! 4000 RPM is perfect for a souped up cummins tach! I'm not going to turn mine past 3200.
Putting a tach on a diesel is a clean deal if you go shaft drive. The Cummins engines have a tach drive adapter that screws into the timing cover to replace the oil fill spout over the IP gear. There are a half a dozen different ways to put oil in a cummins so I'm not concerned about losing my fill spout.
I know what I'm looking for now. If anyone runs across one let me know! I'd prefer the gauges to be in nice shape, but I can rechrome the bezel if it's pitted.
Thanks!
Thanks!
re: F-600 cluster
I've got several of them that I don't need. Pay the shipping and you can have one. PM me the details. I think I might be at the shop again tomorrow, so I can grab it then.
re: F-600 cluster
Keith if you have an extra one after Dustin gets one I will take one.
I'll have to look, but I'm pretty sure I can help you out. Stand by...mljjones67 wrote:Keith if you have an extra one after Dustin gets one I will take one.
- 71PA_Highboy
re: F-600 cluster
I have been looking at getting the Vacuum gauge on the other side to be rebuild as a pressure gauge dso that I can monitor turbo boost... I think the 3 would be the best setup for a 4bt....
Eric
![2 cents :2cents:](./images/smilies/icon_2cents.gif)
Eric
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1 Lincoln Mark VIII
- Manny
re: F-600 cluster
Am i mistaken or is the sw there for stewart warner instruments????
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
- 71PA_Highboy
re: F-600 cluster
You are not mistaken.
hth,
Eric
hth,
Eric
Got Ford?
1 Lincoln Mark VIII
1 Lincoln Mark VIII
- Hawkrod
re: F-600 cluster
Guys, there is also an electronic 4500 RPM tach from 78 and 79. I got mine from an F600 with a 370 and it is designed to work with Duraspark. I have not figured out the wiring yet as I got it on a fluke at a scrap metal dealer who "does not sell parts" (I begged and he gave me the cluster, I must have been pretty sad looking!) so I did not get the wiring but I did pop the hood and check. Below are pictures. Hawkrod
![Image](http://mysite.verizon.net/tcherry3/pictures/F600tach1.jpg)
![Image](http://mysite.verizon.net/tcherry3/pictures/F600tach.jpg)
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
