Turn signal options
MadMaxetc
Turn signal options
Post by MadMaxetc »
My 250 has a HD blinker on it. What do I need to change so that I can run a normal one. The HD one is way to slow.
Dan
FORD Girl
Photobucket Pictures
kaptnkaos
re: Turn signal options
Post by kaptnkaos »
Hey Max...
My '68 CS did that for years... I always thought it was the blinker so I replaced it several times and could never figure out why it blinked so slow.
Come to find out there were two separate blinker units. After I replaced them both, they worked perfect...
You might wanna check that out...
KaptnKAOS
MadMaxetc
Post by MadMaxetc »
I looked for the second (emergency flasher) but couldn't find it.
In the glove box there is the bracket for the switch, but the switch is gone and it has what looks like a factory type plug in it.
I looked at the wire diagrams and mine doesn't folow the same path as what it shows.
I will continue to investigate.
Any other sugjestions??
Dan
FORD Girl
FORDification
Site & Forum Admin
Site & Forum Admin
Post by FORDification »
Yes, there should be two. On a standard truck, one is clipped to the back of the instrument panel....I'll bet that's the one you haven't found.
On my '67 CS, the heavy-duty flasher is a large gold box, attached to the back of the steering column support.
MadMaxetc
Re: re: Turn signal options
Post by MadMaxetc »
FORDification wrote:Yes, there should be two. On a standard truck, one is clipped to the back of the instrument panel....I'll bet that's the one you haven't found.
http://www.fordification.com/images/67- ... ping04.jpg
http://www.fordification.com/images/67- ... ping02.jpg
Found the Large gold box. I looked for the one on the back of the gages, but couldn't even find the plug for it. The big box is easy to find, it shakes the dash when it "flashes" :lol:
Dan
FORD Girl
foghorn
Post by foghorn »
Some had a flasher stat in the fuse box. Also you should have one for emergency flashers along with turn signals.
Foggy 8)
Work is for people that dont know how to fish
HurleyInt824
Post by HurleyInt824 »
i found mine on the driver side frame rail, just past the cab... i had my factory emergency flasher on the frame rail in my 68 250 CS
