f600 gauge swap question
jcolville
Post by jcolville »
I know there is something on this someplace but I can't seem to find it....I have an f600 cluster and the connector is different than the one on my 72...the wire colors seem to be the same, can I just hook them up wire for wire? I have gauges in my old one, not idiot lights.
kaptnkaos
re: f600 gauge swap question
Post by kaptnkaos »
Hey JC...
I think you can...
I think if you remove the harness plug from your original gauge cluster and swap conectors, the f600 cluster will plug and play...
You should be able to gently pull the wire out of each of the plug sockets and put them in the other connector one by one until you have the whole connector switched over...
I don't think you will need to cut any wires...
I have never done this before, so please make sure I haven't given you the wrong info before tearing anything a part...
It might depend on the year of each... but I do think that's all you will need to do.
Good luck...
KaptnKAOS
fmartin_gila1
Post by fmartin_gila1 »
Don't know about the colors matching, prolly have to find both diagrams and compare. You can't just pull the wires out of the connectors, they have to be unlatched, then can be pulled out. Most times a ice pick or something similar will work for a unlatching tool.
Fred
71 LONG BED
Post by 71 LONG BED »
Yup, wire for wire. There is one wire that's different. If my memory serves me correctly (witch it doesn't always do), brown goes to purple. Don't worry though, it's the only two wires that don't match, so you'll know which ones they are. :thup:
John Member #1549
Image Image Image
MadMaxetc
Post by MadMaxetc »
To get the conector appart you can get the tool from any auto parts store. I got the tool to do my turn signal switch. I have also used a short section of un-flared brake line (3/16").
Dan
FORD Girl
Photobucket Pictures
fitzwell
Post by fitzwell »
MadMaxetc wrote:To get the conector appart you can get the tool from any auto parts store. I got the tool to do my turn signal switch. I have also used a short section of un-flared brake line (3/16").
yep...terminal disconnect tool. 725153 Belden available at your local Napa
jcolville
Post by jcolville »
sweet! thanks gents!!..I may just go back to the bone yard and get the connector out of the f600 to make it look all nice. I hade the gauge bezel powder coated and mounted a nice tach in the right side of the bezel. I also had the radio bezel powder coated but it looks kinda odd with the heater controls having the chrome around the edge, I'll prolly have to take that out now and get that done or get another radio bezel and have them just powder coat the black and not the chrome outside edge. If anyone wants me to post a pic of the cluster let me know and I will.
kaptnkaos
Post by kaptnkaos »
ooopps sorry man
I plum forgot about the latches :doh:
KaptnKAOS
71 LONG BED
Re: re: f600 gauge swap question
jcolville wrote:If anyone wants me to post a pic of the cluster let me know and I will.
:doh: My goodness, you have pics and haven't posted them yet??!!Image
Just kidding, of course we wanna see! :thup:
John Member #1549
Image Image Image
jcolville
Post by jcolville »
OK ..I got the cluster all in, wireing was easy. 71longbed was right about the two wires, purple and brown. I did have a black wire with a green strip too but the connector didn't have it going anyplace. I'll get some pics of it for ya.
71 LONG BED
How do you like it? I love mine, it's much easier to read as your driving. I have one for my F350 also, but I'm still waiting for my buddy to weld up a hole drilled in it for a toggle switch. :roll: I should bug him about it. :P
Lets see those pictures. :D
John Member #1549
Image Image Image
