Aux fuel Switch
kid
Aux fuel Switch
Post by kid »
My 250 came with the aux tank but no switch. I need to know where is mounts under there. The truck had the factory long AC unit so there are plenty of holes and I have not seen the wiring harness yet for the switch.
Any one have the wiring diagram for the aux switch? i.e. color codes.
71PA_Highboy
re: Aux fuel Switch
Post by 71PA_Highboy »
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
kid
Post by kid »
Thanks I don't have that under dash connector the under frame one is missing too.
kid
Post by kid »
got it
bugly truck
re: Aux fuel Switch
Post by bugly truck »
eric,
I'm confused...I have a 71 f250 with the dual tank set up, but I thought the switch in the first pic was the selector for the fuel gauge.. on the wiring diagram it refers to it as a fuel pump selector???? my truck has the engine mounted fuel pump...is there an electric one or something or is that a different version than i have on my 250???
I alway thought when i change over tanks (which I don't do very often) the fuel pump just pulled the fuel thur the line after I move the selector that is on the floor???
ken
you are right these trucks dont have in tank pumps.
Thunderfoot
re: Aux fuel Switch
Post by Thunderfoot »
Yeah, the diagram is mislabeled, just one of a few mistakes I have seen on some of the diagrams... It is just switching the sending wires for the fuel gauge on the dash...
