Fuse Box. Where and how many
The_Eman
Post by The_Eman »
68 F100 2wd
The only fuse box I've been able to locate is under the instrument panel on the left side of the cab. Not many fuses in there. Is there another box somewhere?
thx,
Eric
no that is the only one with about 5 or 6 fuses is all you will have in it at any time. of course ford does use fuseable link wire. if it burns in two then the wire will not send power to the part its attached to. have you checked out www.fordification.com/wiring.htm
The_Eman
re: Fuse Box. Where and how many
Post by The_Eman »
I have checked out the wiring section but there isn't much on the 68. Will the 69 circuits be similar?
thx,
E
Thunderfoot
Post by Thunderfoot »
Yes the wire diagrams for 68-70 are basically the same (not completely sure on the 67) and 71-72 are the same...
mrung0wa
Post by mrung0wa »
FYI: I have many additional inline fuses underneath the hood on both fender walls.
That's where there likely to be located.
Lawrence Image
http://www.fordification.com/galleries/ ... ?pos=-2746
FOR SALE: 64 Galaxie 390HiPo C6 (Project Car)
SOLD! 69 F100 Contractor SPECIAL 300 I6 "Jethro"
01 BMW 325i 4DR E46(Wife's car)
03 EXPEDITION XLT FX4(2WD/AWD/4WD) 5.4L K&N FipK
"I beat my head against the wall, Because it feels good when I stop."
19674x4
Post by 19674x4 »
yea fuseable links are muy popular. and when they blow, its a search in itself to find the one you need to replace.
My Photo Album
bugly truck
Post by bugly truck »
Hey e-man,
When i bought my bump a couple years ago...wow has it been that long???...anyway, the PO had completely butchered almost all of the underhood wiring...even had installed a "kill switch" because the ignition switch was broken or so he said...
anyway the point of my post is the fordification wiring info is great and I have used it several times, but I also bought a cd (from e-bay, I think)with the wiring diagram for my 71 and have found it to be very helpful in redoing some of the more confusing wiring, both under the hood as well as under the dash, which was also pretty tore up!!!
good luck,
Ken
The_Eman
Post by The_Eman »
Thanks Ken. Yea, I just bought a wiring book for the 68. I fixed most of my wiring problems... the usual, turn signals, brake lights, and all the other lights. Just a couple more to go and I'm off to concentrate on the suspension.
