Herculiner
theskytoucher
Herculiner
Post by theskytoucher »
I did a search on using herculiner on the floor boards cause i wanted t see some pics of wat it looked like finished but all the pics that were posted specifically by Jor and sharkdance were no longer available so i was wondering if anyone had some pics of wat it looks like finished???
-Troy-
1996 Dodge ram 1500 4x4
1976 Ford F-150 4x4
Quando Omni Flunkus Mortadi
When all else Fails Play Dead
Supermike
Post by Supermike »
I'd like to see some "finished" shots as well... this seems like it would be a good alternative to rubber, and would allow you to lay carpet over it later if you wanted.
Current owner of a 2022 Ford Bronco Wildtrak
kaptnkaos
re: Herculiner
Post by kaptnkaos »
hey Guys...
I don't have any pics, but the '71 CS I parted out had the floor done with bed liner paint.
It was brushed on instead of sprayed, but still looked pretty good.
It would have looked really good had it been sprayed on.
But even brushed on, it would make a great base for a stock style rubber mat or carpet.
You might even want to add some of this stuff to the bed liner paint.
It is a real good insulator and would help keep some of the engine/road heat as well as noise down.
http://www.wicksaircraft.com/c.....index.html
The link came from a forum post about making Homemade Lizard Skin...
KaptnKA 8) S
jor
re: Herculiner
Post by jor »
Here's a few of my 67 and 68. One advantage to posting directly onto the site is the photos won't disappear as they do when one switches photo hosting sites.
jor
kaptnkaos
re: Herculiner
Post by kaptnkaos »
Hey Jor
thanks for the pics
yep... that looks the same as the '71 I parted out...
KapnKA 8) S
1971fordcustom
re: Herculiner
Post by 1971fordcustom »
Ever think about puting fiberglass down?? Thats what we did on my foor. If you do it right it can look like a new boat :lol: + it will all ways be there
1971 F-350 Flatbed
1966 Ford Galaxie!
1966 Ford F-250 4x4
1960 Ford F-750 FireTruck
1960 Gmc 6000 FireTruck
1962 IH R-185 Firetruck
1959 Ford Custom 300
1940 Ford Truck
theskytoucher
re: Herculiner
Thank you very much Jor thats exactly wat i needed to see!!!! One question though how did you attach the trans tunnel and make it look right, and be removable? Thanks
-Troy-
1976 Ford F-150 4x4
heep70
re: Herculiner
Post by heep70 »
I used the Dupiliner in my Toyota floor boards. i liked it because it is alot smoother then the hurculiner. The Hurculiner I did in my old jeep was way to abrasive. To hard to clean out the cab floor, but good for the bed though.
Oppss, the first pic is of the POR 15. The next one is of the Dupiliner.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
theskytoucher
re: Herculiner
I think i like the dupiliner better!!! Does it seem to be holding up pretty good??
-Troy-
1976 Ford F-150 4x4
jor
re: Herculiner
Post by jor »
Yea, I think if I were doing it again I would also use the Dupiliner as heep did in that the Herculiner is indeed very abrasive (good for the bed though). As far as the transmission hump goes, that's just a stock removable cover with some aluminum bolts.
jor
69F110
Post by 69F110 »
Great idea. I am going to have to work on getting some of this Dupiliner stuff...I take it you POR-15 it first, then Dupiliner?
Steve Davis
Pastor and U.S. Army Retired
Supermike
Post by Supermike »
What would be the reason to lay down POR-15 and then Dupiliner?
Is the Dupiliner just brush-on, or does it need to be sprayed?
heep70
Post by heep70 »
Supermike wrote:What would be the reason to lay down POR-15 and then Dupiliner?
I did the POR15 because the floor pans had a lot of surface rust. I replace some parts of the pans, but decided to use the POR15 also.
If you do use POR15 make sure you either dupiliner the pans soon after the POR15. If you wait to long then you wil have to etch primer on top of the POR15 then use the Hurculiner.
My Toyota sees alot of wet, it is a trail rig.
Greg
HH Henderson
Post by HH Henderson »
I found a spray can of Herculiner at O Reillys and used it on my tail gate. It is much smoother than the gallon can. Have you thought of this.
HH
"any man who can drive safely while kissing a pretty girl is simply not giving the kiss the attention it deserves Einstein
http://www.satisfaction.com/photobucket-login/
1968 Ford F100 360 cu (ole blue)
1971ford
Post by 1971ford »
ooo im glad you bumped this up :D
i am planning on doing this to my 71 f250 desert truck.
whats the noise like though? its it any louder in the cab?
do you have to strip down to metal before applying dupiliner?
-Ryan
